Results 1 to 2 of 2
Thread: E38 PCM controlling aftermarket Spal brushless pwm fan
    Member Age08's Avatar
    Jun 2012
    Default E38 PCM controlling aftermarket Spal brushless pwm fan
    I have found a weird glitch in the E38 pcm, I am trying to control a 17" spal brushless PWM controlled fan the frequency and voltage are with in specs of what the e38 outputs. the spal fan work's in reverse to the factory PWN siemens fan controller, on that 89% fan speed in the program equal 10% of the spal fan and 10% in the program equaled 89% for the spal fan.
    When I inverted the two tables something weird happen when I tested it, the spal fan would come on at first but once the car got over 70-80c the pcm stopped putting out a pwm signal and the fan shut off.
    Im guess there some weird logic that doesn't like to the fan duty cycle go lower when engine temp increases.
    Thanks for posting.
  1. P59 PCM and PWM fan Control
    By route in forum Gen III V8 Specific
    Last Post: July 18th, 2020, 06:45 AM
  2. E38 and aftermarket speedometer settings
    By LS-SWAPPER in forum E37, E38 & E67 PFI ECM's
    Last Post: May 20th, 2018, 03:43 AM
  3. E-fan controlling on 02 Chevy truck
    By aaronr in forum Gen III V8 Specific
    Last Post: May 22nd, 2012, 09:06 AM
  4. 8.1L PCM Controlling 1991 to 93 4L80E
    By 1BadAction in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 12th, 2012, 09:18 AM
  5. E38 pwm cooling fan control
    By vette5797 in forum Conversions / Aftermarket Parts
    Last Post: December 24th, 2009, 05:07 AM
