Results 1 to 2 of 2
Thread: Selecting tables
    Jun 2021
    Default Selecting tables
    When creating a CSP tune and messing with fuel limiters. There is one for boost pressure and barometric pressure fuel limiter. Where do you select which table to use? Or are we able to turn a table off completely? I know with the air density you can select just one table so it will not use 2-4. That is probably the hardest thing I am fighting creating my first set of tunes is how do you make sure two tables don’t compete against each other. Thank you for all your input. Is there any online manuals for EFI live that describe the different tables and their functions in detail?
    Lifetime Member comnrailpwr's Avatar
    Jun 2011
    Just get rid of them by maxing them out or use them if you want. Your over thinking it. The ECM will use the lowest value of all the limiters.
    Sent from my SM-G970U using Tapatalk
  1. Selecting Cells
    By Blacky in forum V8 Tune Editor
    Last Post: October 1st, 2020, 08:07 AM
  2. Selecting LBZ PIDs
    By Jester296 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 10th, 2012, 02:18 AM
  3. selecting pids on v2
    By Aint Skeered in forum FlashScan V2 BB Logging
    Last Post: December 9th, 2008, 04:44 AM
  4. selecting pids files ?
    By drdarthinvader in forum FlashScan V2
    Last Post: October 12th, 2008, 08:30 AM
  5. Selecting PIDs
    By mnotx in forum FlashScan V2 BB Logging
    Last Post: September 6th, 2008, 01:12 AM
