Results 1 to 2 of 2
Thread: 03 Lb7 Duramax Allison 1000 electric 4x4 to manual 4x4??
    Jul 2013
    Default 03 Lb7 Duramax Allison 1000 electric 4x4 to manual 4x4??
    I am converting my truck from electric push button 4x4 to manual shift 4x4. what do I need to change so when I'm in 4-lo my trans wont go to limp mode? or is there a way to wire in a series of switches so the PCM knows when I'm in 2wd 4hi N and 4lo?
    truck is a 2003 lb7 with 5 spd Allison 1k
    thank you in advance
    Jul 2013
    I guess I should say "what do i need to change in the PCM" or how to let the PCM know what range im in? I hardly ever use low range so I would be fine using the high range shift points (rpm based) the only thing is when I would be in low range the Vss is off by low ratio vs 1:1 in 2wd 4wdH and then the trans thinks its slipping and goes to limp mode. I could turn off slip limit but then if I really do slip it (in 2wd or Hi) i wouldnt know it before its really too late.
  1. Ls1 auto transplant into manual landcruiser 4x4
    By scv8 in forum Gen III V8 Specific
    Last Post: October 26th, 2014, 06:08 PM
  2. Can not flash TCM in 2001 GMC LB7 excab 4x4 pickup?
    By 2001-GMC-LB7 in forum Allison 5 & 6 Speed
    Last Post: August 31st, 2010, 05:14 AM
  3. 99 5.3 4x4
    By drdiesel in forum Gen III V8 Specific
    Last Post: September 20th, 2009, 11:24 AM
  4. 4L60E 4x4
    By nissmo in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 26th, 2008, 07:21 AM
  5. 4x4
    By captainron in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 9th, 2007, 09:26 AM
