Who here has flashed a CM848? Has anyone BENCH flashed one with a Bench-Force?
Bench-Force should work well with these as it is done through the J1939 connections (which I am sure they have on their setup).
Through J1939 you can read and flash, I don't think reading is possible via the SCI bus on the vehicle (via the OBD-II port).
Edit: Please note that CM848 & CM846 (the early Dodge ECM's) are read and flash only, we don't support editing of these two ECM's and likely won't in the future.
