Results 1 to 3 of 3
Thread: What segment of a LML/LGH file stores what?
    Jan 2011
    Default What segment of a LML/LGH file stores what?
    Hello,
    What segment of the file stores what?
    Same segment numbers should have the same configuration?
    Engine performance settings?
    Once a file has been modified and the segments stay the same, obviously they some will be different.
    Is there a way to modify just a segment?
    Sorry, just interested and I couldn't sleep last night
    Matt
    Feb 2022
    Yes. You can open your file in the editor. Then open a comparison file with the same main OS. Go to edit and do segment swap. It will copy individual segments from the compare file to your main file. Save it as a different name name and then you have what you want. Ie, if you need a different fuel segment but everything else lines up then find a file with the fuel segment you need and segment swap it into your file.
    Feb 2021
    Im also curious about this, can we get a bit of an answer please?
  1. 2015 lml/lgh vats
    By Kennedy Diesel in forum Duramax 2011+ LML / LGH
    Last Post: October 6th, 2019, 04:50 AM
  2. LGH 2011 CAL file OS 12646249
    By shay in forum Duramax 2011+ LML / LGH
    Last Post: May 3rd, 2016, 11:24 PM
  3. Stock File Segment Swaps
    By Cummins610 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 6th, 2015, 05:36 PM
  4. Lml / lgh
    Last Post: March 10th, 2011, 01:41 PM
  5. i need a 4l8o segment file
    By CurtD in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2006, 02:27 AM
