Thread: cm2100 not getting commanded fuel
    Nov 2019
    Default cm2100 not getting commanded fuel
    Someone take a look at this file. This truck is kicking my ass. Looking at the log and back at the tune everything should be calling for 3000uS I can barely get 2300uS out of it. Am I missing something obvious or do I have a weird base file/ecm issue.
    Jan 2016
    Here you go. It should hit commanded quantity and PW Do some more logs. I redid you PW tables with the same max numbers you used but fixed the rest of the table as they were all a messed up and will give you problems down the road if they weren't changed. Also made a few other changes to help you out.
    BurgessCSP510MMtry3_Rev_1.ctz
    Nov 2019
    Quote Originally Posted by Orange Stroker View Post
    awesome I'll take a look at it. Mind telling me what the holdup was on it that I couldn't find?
    Nov 2019
    nevermind. I think I found the smoking gun when I looked up the differences. Yea some of my tables were off because I was trying to figure out what was limiting this thing. I appreciate your help and will give it a try
    Oct 2020
    Just curious. Is this a 6.7 swap or are you having problems in a dodge ?
    Quote Originally Posted by 6.7Guy View Post
    Nov 2019
    Quote Originally Posted by andyman View Post
    In a dodge. But its not anything on the dodge side that i missed.
  1. Commanded fuel limiter
    By arinkuddy in forum Cummins 5.9L
    Last Post: June 10th, 2019, 03:51 AM
  2. Commanded Fuel when Cranking
    By gpr in forum Gen III V8 Specific
    Last Post: March 11th, 2013, 11:33 AM
  3. Commanded fuel pressure Question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: April 11th, 2012, 09:40 PM
  4. Commanded Fuel Pressure
    By Compcowboy in forum Cummins 6.7L
    Last Post: January 5th, 2012, 01:04 PM
  5. commanded air fuel
    By 69camaro5speed in forum General
    Last Post: March 11th, 2007, 12:37 PM
