Results 1 to 2 of 2
Thread: Isx cm2350
    Mar 2019
    Default Isx cm2350
    Hello. I'm looking for a factory file from a ISX CM2350 600/1950. I want to make sure my RV has the factory calibration in it before I make any changes.
    Thank you in advance.
    Normally you would just read the ECM and keep that file as your stock tune.
    From my experience there is countless variations of tunes in the CM2350A ECM, you would have to provide the E/C number printed on the ECM as a starting point if you can't read it.
  1. CM2350 on the Dyno Keeps coming up with SCR1
    By Twistedshafts in forum Cummins 6.7L
    Last Post: October 14th, 2020, 11:24 AM
  2. CM2350 Modes
    Last Post: September 21st, 2020, 08:40 AM
  3. Cummins Stock file 2013-UP CM2350
    By GM-Josh in forum Cummins 6.7L
    Last Post: February 12th, 2018, 08:21 AM
  4. CM2350 Bench Connection
    By DemonDMAX in forum Cummins 6.7L
    Last Post: September 25th, 2017, 11:01 AM
