Thread: Scanning AFR Err
    Jul 2021
    Default Scanning AFR Err
    Hi guys,
    I have been a HPTuners user for a while and now have purchased EFI Live as well.
    When tuning the VE table using HPTuners I usually setup the scanner to log AFR Error in % (Commanded AFR vs Actual AFR), I have wired my Innovate LC2 Wideband directly to the HPTuners MPVI2 unit.
    This works very well and allows me to update and correct the VE table very quickly.
    How do I do the same with EFI Live's scanner and the V2 Flashscan unit ?, does anyone have a nice tutorial explaining step by step how to do this ??
    Any help with this would be greatly appreciated.
    Cheers Rick
    Aug 2016
    Did you ever get this sorted out?
    Jul 2021
    Quote Originally Posted by RC1 View Post
    Hi yes thanks, I found some info online and managed to figure it out.
    You can use Commanded AFR and Wideband AFR...
    I prefer to use Commanded EQR and Wideband Lambda, the BEN correction is the product (i.e. multiplication) of those (don't have to remember which is numerator/denominator)... the Calc.VET thread shows how to setup a calc pid for this.
    Rick_Abraham,
    Welcome to EFILive
    Are you connecting your LC-2 using the 5V analog interface or the Serial Comm interface?
    Jul 2021
    Hi am using the 5V analog interface
  1. SM-AFR, DM-6 WIDEBAND AFR GAUGE COMBO good for EFILive Monitoring?
    By Black LS1 T/A in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2016, 04:11 PM
  2. Commanded AFR not equal to WBo2 AFR at idle.
    By macca33 in forum Gen III V8 Specific
    Last Post: April 6th, 2012, 12:56 PM
  3. Err 1400, Invalid Window Handle
    By Mr. P. in forum Do you want to be a Beta Tester?
    Last Post: December 20th, 2009, 03:12 PM
  4. Cold AFR doesn't follow commanded AFR
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: August 17th, 2009, 02:50 PM
  5. At idle OL AFR good, CL 16 AFR
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2006, 11:40 AM
