Anybody have one??
Anybody have one??
'71 chevelle
Twin turbo ls1
1000 HP 93 octane street car!
96 lb injectors
You may have to start with a 2001 because there isn't one on Tordne's site. I can send you one that's slightly modified, but unfortunately, my stock tune is stored in a different format because I started modifying before FlashScan was available.
DigitalEFI- EFILive US Distributor
sales@digitalefi.com
678/344-1590
It not in .bin format is it (the stock one you have)?
If you do find one please email onto me and I'll add it for all
Andrew
EFILive Crew
I'll try to get it converted. To do that, I have to load it back into the PCM, then read it out with EFILive. I'll try to get it done by the weekend.
678/344-1590
Mate, that all sounds a bit to involved...Originally Posted by dfe1
Andrew
EFILive Crew
Not too bad really, it's just taking the time to retreive the other cable and do the multiple downloads. All the .tun files I have are pretty highly modified. The truck is a stock extended cab with 3.73, and I've just been playing with various tuning mods to see the effect. Nitrorocket, depending on what you're trying to accomplish, you may be better off starting with the 2002 6-liter file and changing the engine size and injector constant to the 5.3 values. Values for B4001 (Injector Flow Rate) are 24.8 pounds per hour, B0104 (cylinder size) is 666 cc. That should get you off and running.Originally Posted by Tordne
678/344-1590
What is done to the tune??? You can send it to me at scotmich@wi.rr.com
'71 chevelle
Twin turbo ls1
96 lb injectors
I am looking to modify just about everything.... sounds like your tune would be great, I could just tweak on it a little, but it might be close.
Let me know. Thanks.
'71 chevelle
Twin turbo ls1
96 lb injectors
You've got mail.Originally Posted by nitrorocket
678/344-1590
