Results 1 to 10 of 16
Thread: 96lb injectors can be tuned to idle perfectly!
    Jun 2005
    Default 96lb injectors can be tuned to idle perfectly!
    Just letting you know that if they were afraid to use 96lb/hr injectors with a driver for fear of running to rich, it is possible! I have a 1000 hp car (on 93 octane) that idles at 15:1 AFR!!! You dont have to be stuck with too small an injector.
    I love LS1's!
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Jul 2005
    i'll take bragging with a side of data, please
    Jun 2005
    I don't mean to sound like I am bragging.....well no too much.
    I just wanted people to know this because everyone seems to be using 60 or 75 lb injectors with 80 psi of fuel pressure to try to make there car run right. You can do it with a 96 lb injector a 45 psi fuel pressure and a 725 rpm idle!! Again, I love this software!
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Jul 2005
    you completely missed the point. if you got injector that big to run that low of a rpm properly, congrats, you SHOULD be bragging
    my point was that it would be nice and in a true spirit of forum info swap if you also provided us with technical info alongside the bragrights--what IFR, what voltage offset table, anything else needed to get changed, and how much?
    Jun 2005
    Well, after I try to sell my tune file on ebay, I will disclose the info.
    No, seriously. I rescaled the IFR table from the LS1TECH Excell conversion. You will never believe how I made them idle lean enough....it was so easy! all I did was cha
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Quote Originally Posted by nitrorocket
    Did I miss this or did you not finish typing...?
    If you reveal how you did it, you will be a tuning hero...
    Jun 2005
    The entire trick is the small pulse adjust table, you can modify this to get the fuel down on the pulsle widths.
    Funny thing though???? It worked great for me on the closed loop SD (14.7 idle), But open loop idle will not go leaner the 12.5:1 now?? I dont understand what the difference in Open loop and closed loop could be???
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Lifetime Member ZL1Killa's Avatar
    May 2005
    LOL.... Open loop... don't you love it. now put the car back in Closed loop and let the billion dollar computer do its thing. So many stupid screwy things my car did when in OL with the 60#ers... cut the AC on and it surged back and forth and went way lean!!... so i'm going to let the billion dollar computer do the work for me
    yep, small pulse adjust. and possibly def and min injector puls width; cuz i was on my way with tuning the 60#ers in but ran out of time... had to get back home... but 42.5#ers will do the job i need to do and I was immediately able to sell my 60#ers
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
    Jun 2005
    What is also wierd is that in closed loop my AFR's fluctuate about .5-.75 overall point. In open loop they are more inline within .2 or so but at idle it is a little richer?? Pretty wierd huh??
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    nitrorocket, I still have respect for you as this monster combo was your first tuning job with EFILive, awesome effort . Often people ask "How hard is it to tune", I usually start off with "Well, there's this guy on our forum........"
  1. Nube trying to figure injectors tuned!?!
    By chevroletfreak in forum Gen III V8 Specific
    Last Post: January 29th, 2008, 03:52 AM
  2. 83lb injectors SD idle quality
    By B A Barakus in forum General (Petrol, Gas, Ethanol)
    Last Post: December 23rd, 2006, 11:04 PM
  3. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
  4. How are you 96lb injectors at idle??
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2006, 05:02 PM
  5. Who has 96lb injectors?
    Last Post: September 1st, 2005, 09:24 AM
