Results 31 to 36 of 36
Thread: CALC.VET Struggles, VE Values Don't Seem Sane
  1. #31
    Mar 2009
    I just did a review of my 411 install because I was missing a constant power wire, or so I think. I emailed Lextech to get clarification on that one as his document doesn't instruct you to add a 2nd constant power wire when 411 swapping a 97, but 98-00 actually have this wire in the harness and use it with the 411. At any rate, here's what I observed with the DMM:
    Battery: 12.21V
    C1-20: 12.21V (constant)
    C1-19: 11.48V (switched)
    C1:75: 11.68V (switched)
    So at this point I need to figure out how this truck is wired so I can narrow down where the voltage drop is. My gut says go right to the ignition switch, we'll see. At the end of the day I'm looking for a component that gets 12.21V in and spits out considerably less. Good call on logging voltage statesman! I'll have to add that to my list of stuff to watch.
  2. #32
    I have seen PCM is always 0.5 to 1.0 volts lower than DMM.
  3. #33
    Mar 2009
    I didn't even check the PCM with EFILive as I figured I had a smoking gun with that .5-.7V delta on the DMM switched vs constant. My concern with the discrepancy observed between switched and constant is that switched is what powers the injectors. Crap, I should have compared switched PCM vs the injectors now that I'm typing this. I know the injectors respond differently based on voltage, is that the concern here? Because the charging system itself was good to go way back when I initially checked it.
  4. #34
    Aug 2013
    Quote Originally Posted by Supercharged111 View Post
    You can tune out a voltage discrepancy as long as it's a constant discrepancy... my main concern is that your charging system is not working properly.
    If you're confident that the charging system is good, then don't worry about the voltage discrepancy. Personally, I'd be checking for resistance in the main power wire between the alternator and the battery. Even if you're happy with the ECM registering a lower voltage than your DMM... you should be concerned that your ECM voltage reading is showing your voltage dropping during WOT conditions.
  5. #35
    Check voltage drop between alternator and battery pos as statesman said, and also check voltage drop between battery neg and ground (at alternator body).
    If you have access to an oscilloscope, look for ripple in alternator/battery voltage.
  6. #36
    Mar 2009
    Yeah, I didn't check anything under load. I was fixated on the wrong thing.
  1. Replies: 80
    Last Post: April 13th, 2020, 08:43 AM
  2. Did I do calc.vet right?
    By bubba68ss in forum Gen III V8 Specific
    Last Post: November 23rd, 2018, 08:19 AM
  3. Calc VET Again
    By pormgb in forum Gen III V8 Specific
    Last Post: September 8th, 2013, 02:54 AM
  4. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 01:20 PM
  5. Some PID's values don't fit in the chart...
    By joecar in forum General
    Last Post: March 17th, 2008, 04:00 PM
