Results 1 to 10 of 11
Thread: CM2350 VGT Delete
    Senior Member Jim P's Avatar
    Nov 2019
    Default CM2350 VGT Delete
    Those that have done VGT delete on their CM2350 trucks, what parameters were changed? I'm fighting something causing fuel to be held back and can't seem to figure out what. It's like it's still trying to do turbo speed estimation and seeing things aren't what it's expecting so it's derating or something.
    Nov 2019
    Engine torque state I get when trying to go WOT is state 14, which is defined as fueling torque derate override state.
    Nov 2019
    Well got the fueling torque derate override state taken care of but now up against an altitude derate, FML, lol. What a headache
    Jan 2020
    Removal of the VGT function is a betch.
    There are also multiple ways to do it. Disable the function and/or the codes, as well as the turbo speed torque limiter, and that takes care of it. The real headache becomes installing an aftermarket exhaust brake, like the Fleece unit... Codes and torque limiter need addressed but the function needs to remain on for the exhaust brake to function...
    Nov 2019
    Yea it has not been a fun venture lol. I had the turbo and speed estimation and all that turned off but was missing something that had the truck hitting a torque derate, every torque table was turned up and every torque derate enable and suppression I could find was switched. Ended up seeing an AECD torque derate override switch, turned that on and it took care of the torque limit the truck was hitting then I found it was hitting altitude derate afterwards lol. I think I got it taken care of now, at least from the guys description it sounds like I got it. Will remote in to him tomorrow if I can to check the scanner while he is driving. Only thing now is he says his switch isn't changing tune positions. He hasn't tried changing with the autocal itself. Not sure if his switch is an older one that isn't compatible with the current CSP version or not.
    Aug 2022
    Default Question
    Quote Originally Posted by Jim P View Post
    can you tell me what parameter did you change? I have the same problem in my truck
    Nov 2019
    Many many many parameters to change
    Jul 2022
    Is this something that you
    Nov 2019
    Is this something that I what?
    Jul 2022
    Edit to my second attempt: Sorry I was trying to respond via Tapatalk but apparently there's an issue.
    Anyways, I was trying to ask if the details are something that you wouldn't mind either sharing or summarizing. Completely understand if not, just curious.
  1. Isx cm2350
    By Stevec in forum Cummins HD
    Last Post: August 5th, 2021, 01:35 PM
  2. CM2350 on the Dyno Keeps coming up with SCR1
    By Twistedshafts in forum Cummins 6.7L
    Last Post: October 14th, 2020, 12:24 PM
  3. CM2350 Modes
    Last Post: September 21st, 2020, 09:40 AM
  4. CM2350 Bench Connection
    By DemonDMAX in forum Cummins 6.7L
    Last Post: September 25th, 2017, 12:01 PM
  5. 6.7L Throttle valve delete and egr delete
    By Killerram2500 in forum Cummins 6.7L
    Last Post: November 20th, 2012, 03:41 PM
