Results 1 to 3 of 3
Thread: Yet Another EGR thread.......
    Feb 2024
    Lightbulb Yet Another EGR thread.......
    My understanding is the EGR system's purpose is to reduce NOx emissions, also the SCR's purpose is to reduce NOx emissions.
    My question is:
    Is it possible to disable the EGR, and its related codes, checks, etc., And use the SCR to compensate for the change?
    I have already replaced the entire exhaust system from a larger engine series, I'm running the entire system from an LML on the LWN engine.
    It works great and I have roughly 950-1300 miles in between regen cycles. No check engine light and have passed emissions tests multiple times.
    I have no tune and no ECU modifications. I just ordered a FlashScan V3, In my area emissions are done, however, a pass/fail is based on actual tailpipe emissions. (No Emissions related codes present)
    With the larger exhaust, I have a lot of ammonia slip, and I think it will be fine, I just don't know if this idea is possible with the controls of EFIlive.
    My Truck:
    2019 Colorado ZR2, 2.8L LWN engine
    Complete exhaust from Silverado HD (LML), Sensors moved from Stock exhaust, using DEF injector from Silverado.
    It is not possible to delete EGR and it is illegal to do so.
    Feb 2024
    Even if I'm complying with my local Emissions Regulations? I understand in the US, it's a blanket "NO", however, my regulations are actual output not device-related.
    For example, just because all the devices are present, and no check engine light (passes in all US locations) does not mean it will pass here.
    Example: Perkins Tier 4, fails, and must have a larger DPF installed. Which is where I got the idea to install a larger DPF on my truck.
  1. Looking for 80# injector thread...
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: June 13th, 2011, 01:35 AM
  2. Thoughts on this thread???
    By SSpdDmon in forum Gen III V8 Specific
    Last Post: June 9th, 2007, 08:52 AM
  3. Another spreadsheet thread...
    Last Post: December 21st, 2006, 07:05 AM
  4. First Thread
    By TAQuickness in forum Custom Operating Systems
    Last Post: December 11th, 2005, 06:34 PM
