Results 1 to 2 of 2
Thread: CM2200 Base file Edit Error
    Aug 2018
    Default CM2200 Base file Edit Error
    New V3 Flash Scan, new user.
    Every time I try to edit a base tune file for future flashing I get this error.
    It is not locked, it opens and will display parameters but it won't open any table. I tried a E38 ECM file for giggles and same error
    Nov 2005
    Quote Originally Posted by dhoagland View Post
    That error occurs if/when your graphics card driver is not up to date or does not or cannot support OpenGL 3D Hardware acceleration.
    EFILive recommends updating the drivers for your graphics card if possible. Otherwise you'll need to use a different PC/laptop with a more modern graphics card/chip set. Maybe even just updating your Windows operating system the latest available version may help.
    You can look in the EFILive V8 "About Screen" to see what the OpenGL support is on your PC/laptop - that may help you figure out what graphics card vendor you need to download updated drivers from.
    Sent from my iPad using Tapatalk
  1. CM2200 2012 68RFE latest release base file
    By Twistedshafts in forum Cummins 6.7L
    Last Post: May 20th, 2022, 06:11 AM
  2. Replies: 9
    Last Post: March 1st, 2020, 10:44 AM
  3. where to get 2010-2012 CM2200 base files?
    By Chris_pat05 in forum Cummins 6.7L
    Last Post: October 4th, 2017, 06:08 AM
  4. 2012 C6 M6 Base Model - Need base file!
    By GR8GAME in forum Gen IV V8 Specific
    Last Post: April 4th, 2016, 04:44 AM
  5. Flashscan compatable with an Edit file?
    By Nick 02 Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2005, 12:39 PM
