Can some one help me put together a map table for the A0009 boosted VE table? I've been using VE table map with LTFT and also using my WBO2 ref.
If I could I'd like to use A00009 table with WBO2 ref so I can make sure my boosted fuel is correct.
My current pid file. Im maf less and its currently working with my auto meter WBO2 and LTFT vs VE. I just dont know how to build it so I can make the map for A0009. I have 411 PCM with OS 3 in it upgraded from a 2002 camaro file.
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
None None "" "No units"
K Metric "K" "Degrees Kelvin"
R Imperial "R" "Degrees Rankine"
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-032
factor 0 4 .0 "{GM.EQIVRATIO}=1"
*CLC-00-041
AFR 9.63 19.63 0.2 "2.5 * {EXT.AD1} + 10.0"
*CLC-00-042
AFR 9.63 19.63 0.2 "2.5 * {EXT.AD2} + 10.0"
*CLC-00-061
factor 0.5 1.5 0.3 "{CALC.AFR_WB1} / {GM.AFR}"
*CLC-00-062
factor 0.5 1.5 0.3 "{CALC.AFR_WB2} / {GM.AFR}"
*CLC-00-001
% -25.0 25.0 .2 "({SAE.LONGFT1}+{SAE.LONGFT2})/2"
*CLC-00-002
factor 0.5 1.5 .4 "({SAE.LONGFT1}+{SAE.LONGFT2})/200+1"
*CLC-00-003
% 0.0 100.0 .2 "{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)*3445. 2/displacement()*{SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTFT BEN}"
VE 0.0 3.0 .4 "{SAE.MAF.gps}*({GM.DYNAIRTMP_DMA.C}+273.15)*1 5/({SAE.RPM}*{SAE.MAP.kPa})*{CALC.LTFTBEN}"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.AFR_WB1 F041 CLC-00-041 AFR Fueling "AFR Wideband 1"
CALC.AFR_WB2 F042 CLC-00-042 AFR Fueling "AFR Wideband 2"
CALC.BEN_WB1 F061 CLC-00-061 factor Fueling "BEN Wideband 1"
CALC.BEN_WB2 F062 CLC-00-062 factor Fueling "BEN Wideband 2"
CALC.LTFT F001 CLC-00-001 % Tuning "LTFT Average"
CALC.LTFTBEN F002 CLC-00-002 factor Tuning "LTFT BEN"
CALC.VE_Table F003 CLC-00-003 % Tuning "CLC VE Table"
