Results 1 to 5 of 5
Thread: desenitising knock sensors
    May 2006
    Default desenitising knock sensors
    I did a search really didn't get any answers on any of the forums. You must move the knock sensor fequency table up to desenitise them or is there another table. I lowered my timing tables 6 degrees still get 3 degrees on knock retard under load only 1.5 at high rpm I know its false its a 98 and they suck to time. Any info appreciated.
    Jul 2005
    What are your afr's at that point? And how much adv does it have when it picks up det?
    \"You Can Never Have Enough Horsepower\"
    May 2006
    afr is 12.0-12.5 at wot i made it richer to see if would stop the knock it didn't it retarded down to 16 degrees after i took timing out im using a stock z06 timing table from operating system 12221588. I moved the knock sensor frequency up to 6.4 ill see this moring on the ride in to work if that does anything.
    Jul 2005
    It seems to me there are some problems with your knock sensors. Possibly 1 or more are on the fritz? Find out how to check them and do so. It might very well be they are faulty.Otherwise if you feel you dont need them just disable them.
    May 2006
    Quote Originally Posted by caver
    there brand new upgraded ones.
    I found the table to use to desenitise the sensors B6245 it seems this is the same table HP tuners use as there Knock Sensor Global Gain vs MAP vs CYL table the values line up. I put the 1.0's to 2.0 and there is no more knock when i put it under load and it didn't blow up. The new gas and 11.5-11.7 compresson dosen't help either. I still my run 100 power mist fuel.
  1. No knock sensors???
    Last Post: July 9th, 2016, 07:28 AM
  2. Knock Sensors off
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: September 12th, 2009, 03:12 PM
  3. Where to desensitize knock sensors?
    Last Post: October 19th, 2006, 01:32 PM
  4. 98 knock sensors
    Last Post: June 10th, 2006, 10:12 AM
  5. LS2/LS7 Knock Sensors and LS1/6 PCM
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2005, 10:55 AM
