Results 1 to 2 of 2
Thread: CSP Tune Changing Tune Position On It's Own????
    Senior Member Jim P's Avatar
    Nov 2019
    Default CSP Tune Changing Tune Position On It's Own????
    Has anyone ever heard of a CSP tune just changing tune positions on it's own? Got a truck that for some unbeknownst and bewildering reason is changing it's tune position up to switch 4 position. Flash the truck and without the CSP switch plugged into the OBD2 port it'll be in tune position 1, turn the truck off and start it back up and it's in tune position 4. flash the truck and plug the CSP switch in and it will ignore the switch position and just end up doing the same thing, be on switch position 1 till the truck is shut off and restarted and it'll be locked to position 4.
    Nov 2019
    Resolved, tune file got corrupted at some point down the line.
  1. CME (A9134) Turbo Min-Max Position CSP Enable
    By Twistedshafts in forum Cummins 6.7L
    Last Post: May 11th, 2020, 12:47 AM
  2. CSP tune on an already EFI tuned truck
    By rbp4u in forum Cummins 6.7L
    Last Post: February 4th, 2016, 07:37 AM
  3. anyone wanna give me a opinion on this csp 5 tune
    By DieselMafialb7 in forum Cummins 5.9L
    Last Post: August 16th, 2013, 10:43 AM
  4. vin changing- csp
    By johhnyfoxtrot in forum Cummins 5.9L
    Last Post: August 15th, 2013, 03:35 PM
  5. EFILive DSP5, 5 Position Tune
    By GMPX in forum General (Diesel)
    Last Post: April 25th, 2013, 11:30 AM
