Results 1 to 2 of 2
Thread: 2014 ram 3500 Cummins 6.7L
    Sep 2021
    Default 2014 ram 3500 Cummins 6.7L
    i have this code on 4 of my trucks they're all are the same year making model and theyre giving me the same code "p003a" Turbo charger boost control module position exceeded learning limits. i changed the actuator and i pre aligned it and did everything tp fix the issue still nothing. if anyone has a delete file for the turbo id buy it. thank you
    Oct 2012
    Changing the actuator doesn't typically resolve the issue as the turbo is shot.
    I have never run a turbo off file with the VGT in place, sounds like a terrible idea.
  1. 2013 3500 Ram 6.7 with Aisin trans unable to read file
    By staytuned in forum Cummins 6.7L
    Last Post: June 18th, 2020, 10:37 AM
  2. 2011 3500 ram efi live tune
    By VIKTOR in forum Cummins 6.7L
    Last Post: December 6th, 2019, 09:05 AM
  3. 2017 ram 3500 cummins 6.7 p026a
    By Christian_GM in forum Diesel
    Last Post: May 17th, 2019, 04:26 PM
  4. 2011 ram 3500 ecm code
    By mopar-mechanic in forum Cummins 6.7L
    Last Post: December 18th, 2018, 11:25 AM
  5. 2012 Ram 3500 Stock tune 12351331AN Please?
    By crdth in forum Cummins 6.7L
    Last Post: April 15th, 2015, 01:57 PM
Tags for this Thread
