I'm tuning a friends vehicle in which we installed the COS 03 with 2 bar map. Currently the vehicle is set up to run MAFless. The vehicle is a 2003 Silverado SS with twin T04V-Trims. Currently the truck has 60 lb delphi injectors with approximately 45 psi of fuel pressure at idle. With the fuel status per PID SAE.FUEL SYS, set to OL and B4108 set to disable at start up the AFR reads 20:1 then slowly I can see the STFT come on and it goes rich to 13.6:1. From what I have read the PW should be based of the VE and Commanded AFR table if OL is acheived. So with this thought I made a 20% increase to VE table to to lean out the rich idle after the initial start up. This had no effect on the AFR. I'm thinking that somehow I'm not fully in OL. Any help or advice would be appreciated.
