Results 1 to 8 of 8
Thread: Insite file conversion for EFI LIVE
    Sep 2021
    Default Insite file conversion for EFI LIVE
    Hi all
    We have been trying for a while to convert the insite file for an ISB4.5 CM2150e ecu to efi live so that we can tune.
    Can this be done??
    If so how??
    If so can someone assist please??
    Thanks in advance
    Nov 2019
    Quote Originally Posted by velocetuning View Post
    Hi all
    Can this be done??
    If so how??
    Thanks in advance
    Post file and I will try. If successful I will share.
    Hi all
    If the file is still zipped then no, if the file is just an .xcal (eg unencrypted .hex file) then the EFILive software comes with a conversion tool. Have a look in your installation folder.
    May 2016
    i tried to open files from the current incal and from older 2017 incal and efi didn't recognize any of the files, does anybody know what month and year was used to map out these files?
    EFILive does NOT load the files directly, as I stated above your post - "EFILive software comes with a conversion tool. Have a look in your installation folder."
    May 2016
    i understand, remove password, extract file, xcal converts to efi bin . on most of the 2150 files i tried they identify in the compatability_header as a 2100 and xcal wont convert. Not sure what's used but when i look in the header the id matches a calz file but it wont convert or open, i did get prefix FF file BEU to convert but efi doesn't recognize the operating system. I was just trying to help. does anybody have a cal id they want converted? if its supported this wont be a problem. looks like for the 2150 13 operating systems are supported and 2150E there's 8.
    Edit; 13 and 8 config files that may or will cover multiple operating systems..
    Quote Originally Posted by 26sutphen View Post
    The EFILive conversion tool has a checkbox to "Override ECM type check" for this very situation, just be 100% sure your selected ECM type is correct if you allow the override.
    EDIT: Ooops, I see that CM2150E is not an option in the drop down list for the ECM type, we will need to update that, but 2150 C or D will be fine. I'd say the reason is everyone up to this point has just read the ECM's rather than pulling the files off wherever.
    Oct 2010
    Does the CM2450B controller need all this too? I am not sure what insite is
  1. Converting a HPT File to EFI Live
    By Schwanke Engines in forum Gen III V8 Specific
    Last Post: April 18th, 2016, 06:41 AM
  2. Efi Live File Formats
    By auspeed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 24th, 2013, 09:47 AM
  3. Converting a HPT to an EFI Live file?
    By Phantom Z in forum Lounge
    Last Post: April 7th, 2011, 07:27 AM
  4. HELP!!! Converting Efi Live to HPTuners file!
    By 06x6spdGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2010, 11:46 PM
  5. EFI Live V4 xml file for 94 Regal 3800
    By MasterOfTheJawan in forum EFILive V4
    Last Post: December 29th, 2009, 06:40 AM
