Results 1 to 3 of 3
Thread: How to make use of a logged ve pid?
    Default How to make use of a logged ve pid?
    I haven't found anything to help me on this. What we are working on is a 1998 T/A with a 443 cu. in. LS1. I currently tuning with LS1 Edit, which I understand very well. I just got EFI Live V7 today and I am trying to use this data to setup a proper ve table. From what I read in other posts this should be simple, however I can't figure it out. From what I understand I am supposed to export the data into Excel, which I don't know much about, and make a table or something. Could some one please explain this to me. It appears that the one VE pid is reading the same info as what LS1 Edit uses in its VE tables. Any help is appreciated. Thanks in advance.
    Lifetime Member Steve Bryant's Avatar
    Feb 2004
    PHP,
    Take a look at this thread http://efilive.com/forum/viewtopic.php?p=8941#8941 . Then if you send me your e-mail address in a PM I'll send you an excel spread sheet to help you set up VE easily.
    I won't be back home for about ten hours, but you can at least read the thread. It will all make sense in time.
    Steve
    I will definitely check that out. Thanks. I will send you a pm with my email address. I was going off of this post http://www.efilive.com/forum/viewtopic.php?t=184 and thought you didn't have to disconnect the maf. Thanks again.
  1. airflow logged and hp
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: October 30th, 2009, 08:55 PM
  2. Logged RWHP?
    By Spindoctor in forum Gen III V8 Specific
    Last Post: October 23rd, 2008, 12:14 PM
  3. Can milligrams per cyl. be logged?
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2006, 04:27 AM
  4. No frames logged??
    By Garry in forum Black Box Logging
    Last Post: July 7th, 2006, 02:21 PM
  5. Logged...
    By SSpdDmon in forum General
    Last Post: July 26th, 2005, 05:43 AM
