Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Rough Idle Trim issues after VE-MAF Tuning
    Lifetime Member Chalky's Avatar
    Sep 2003
    Default Rough Idle Trim issues after VE-MAF Tuning
    Just finished up VE and MAF tune. Car picked up a rough idle before MAF tune, not bad but worse than before tune.
    Car is also showing slightly positive fuel trims when cruising LTFT and higher when idling. Driver side is +4 when idling and 3.9 under full throttle.
    Pass side is just slightly with worst with thims of .8 and +1.6 at full throttle. AFR is almost perfect match to PE!
    Is that kind of discrepancy between banks normal/acceptable?
    Does VE Table have any impact on idle?
    Commenst/suggestions welcomed!
    2015 Z06 A8
    Jan 2005
    VE will effect idle. You will want to get b4307 in line to help with idle
    May 2006
    I have a slight diff in banks but it ave. it self out. You dont want + lt trims they will add fuel to wide open throttle.
    Sep 2003
    Quote Originally Posted by TAQuickness
    How do I make adjustments in B4307? I never touched this table when doing MAF and VE.
    2015 Z06 A8
    Sep 2003
    Quote Originally Posted by 98SS2836
    Makes me wonder if I need to go back and make another pass with VE table. Lower end is a bit jagged!
    2015 Z06 A8
    Jan 2005
    Quote Originally Posted by Chalky
    There's ton's of info about this table in this forum, so I'll only give you a few more hints, RAFIG & RAFPN
    . I never touched this table when doing MAF and VE.
    Good. You're not suposed to.
    Apr 2005
    Unfortunately, none of it is well organized, and I think most new users will be overwhelmed if they simply search for RAFIG, read all the threads, and then try to decide what to do.
    Sep 2003
    I did the search and review last night. Decided to focus on VE table first and idle cells. They ares still showing very lean.
    2015 Z06 A8
    Jan 2005
    Quote Originally Posted by superls1
    figuring stuff out is half the fun. don't want to ruin it for anyone.
    Sep 2003
    Fully Agree. Still do not understand how B4307 comes into play when the only changes are to VE and MAF table.
    2015 Z06 A8
  1. Rough idle VY Commodore
    By Biggsy in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2012, 01:02 AM
  2. 4L80E rough shifting issues
    By bekmwan in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 26th, 2009, 02:03 PM
  3. rough idle at start up with cam
    By achidotcom in forum Vortec V6/V8 Specific
    Last Post: April 19th, 2008, 03:12 PM
  4. Rough idle
    By aaronr in forum Gen III V8 Specific
    Last Post: December 28th, 2007, 05:08 PM
  5. Anyone with KR issues from rough roads?
    Last Post: September 21st, 2006, 08:03 AM
