Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: LS1B 8.1/4l85 with failed hypertech tune assistance
    Jan 2010
    Quote Originally Posted by Phil_Miller_86 View Post
    This is the only file I have from the PCM and it contains an error.
    Attachment 23889
    LS1B_2004 Avalanche 8.1L 4x4.ctz
    This should be the latest OEM base file for you based on the Vin number from the file you provided. Hope this helps!
    Sep 2021
    Update:
    I received my new PCM in the mail and installed it. I had to do the passkey learn process like three times because the tutorials didn't say I had to try and start it each time to get the light to come on.
    It idles kinda rough, and I haven't done the crank learn yet because it's kinda late to be revving up to 4000rpm.
    I was able to pull a stock tune file(!) so I have something to start with. I need to adjust the tire size and gear ratio to keep from cooking the tranny while I drive it around and get all the systems ready for logging and tuning.
    Mar 2009
    Update:
    Obvious question, but was the stock tune file for an 8.1? I only ask because I feel like it shouldn't idle rough.
    Sep 2021
    Quote Originally Posted by Supercharged111 View Post
    It was put on the PCM by the company that sold it to me based on my VIN. In the very beginning it's a little stumble, the RPM's dip, and then it comes back up.
    Sep 2021
    04 Avy Stock tune w hypertech trans data and fixed speedo.ctz
    Can someone with some experience take a look at this and tell me if it looks reasonable/safe?
    I tried to copy the hypertech-tuned transmission data over from the bad speedo file to the new stock file that was on the PCM, with my calculated speedometer values. The old trans data is from an older operating system, so I don't know if it's okay to put that data on the new PCM running the newer OS?
    I'm moving this week, towing a trailer ~700 miles and don't want to burn my tranny up with bad data (stock or otherwise).
    Sep 2021
    Quote Originally Posted by 1FastBrick View Post
    I thought I posted a reply to thank you, but I don't see it here. I appreciate your help, Thank you.
    Use the V7 scantool.to write the VIN.
    Why did you have to replace the PCM?
    Don't go to the dealer for PCM flashing... they are instructed to lookup the factory bulletins and flash what the bulletins indicate (from the factory database) and/or to replace the PCM (you don't know what they actually did).
    I'll look at your files when I get home from work (next Tuesday).
  1. Need some assistance with a modified tune on my 05 LLY
    By 1FastBrick in forum Duramax LLY
    Last Post: August 2nd, 2017, 12:04 AM
  2. Failed Smog... tune?
    By ferocity02 in forum Gen III V8 Specific
    Last Post: March 27th, 2013, 12:03 PM
  3. Need hypertech/efi cant do
    By JST in forum E37, E38 & E67 PFI ECM's
    Last Post: August 1st, 2012, 01:28 AM
  4. Hypertech damage? What should I do?
    By jonnyk in forum Gen III V8 Specific
    Last Post: November 30th, 2009, 01:54 PM
  5. reading hypertech flash
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 16th, 2007, 08:33 PM
