Thread: oil temperature 07 c6z06/ls7
    Nov 2014
    Default oil temperature 07 c6z06/ls7
    trying to log engine oil temperature. sae.eot-b is n/a, gm.eoilts shows -40 constant, gm.eoilt shows 65
    Nov 2014
    Quote Originally Posted by dian View Post
    Hi dian,
    Did you get it figured out?
    Did you see this thread: E38-Oil-Temp-Sensor-Input
    Nov 2014
    apparently i cannot post. or do my posts show up and i cant see them? i saw the thread, but dont know what to make out of it. does it mean there is no pid for oil temp?
    im quite a bit out of touch, i dont even know what os the car has and i cant remember what cax files are. they dont open for me anyway (https://forum.efilive.com/showthread...nmentost242012).
    maybe something is wrong with my computer, but i can post on other forums fine.
    first post continued:
    Write your post in Windows Notepad, and then copy/paste to the forum.
    Nov 2014
    lets see if i can post here again. o.k., seems to be working. (i trierd copying in here without success.)
    so is there a pid i can log for oil temperature?
  1. Boosted C6Z06 Texas Mile
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: February 28th, 2018, 05:28 PM
  2. temperature vs injectors
    By fezz57 in forum Gen III V8 Specific
    Last Post: September 29th, 2010, 10:50 PM
  3. Question about NEW PID availability... Engine Oil Temperature?
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 24th, 2009, 06:43 PM
  4. coolant temperature
    By ws6togo in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 05:23 PM
  5. Is there a AFR vs temperature setup yet?
    By nitrorocket in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 24th, 2005, 10:06 AM
