Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: September 2021, V8.3.8 Public Release
    Default September 2021, V8.3.8 Public Release
    Attention:
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V7 software: V7.5.37 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.8 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.070 (Sep 20, 2021), Boot Block: V3.00.005 (Oct 20, 2020)
    • FlashScan/AutoCal V2 Firmware: V2.08.177 (Sep 03, 2021), Boot Block: V2.08.009 (Feb 27, 2021)
    Download here:
    Known Issues:
    Issue #1: Importing JTAG E86B files may result in a Boot Software segment checksum error.
    Workaround: None. Don't flash imported files with checksum errors. Don't use the EFILive software to correct checksum errors for the E86B imported files as that does not fix the underlying cause of the checksum error - it just masks the error(s) and causes additional problems.
    Issue #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Issue #3: The [F2: Scan] -> [F3: Data] display was not converting the PID values to non-metric units when non-metric units are selected.
    Workaround: Fixed in Update 1
    Issue #4: When black box logging multiple controllers, DMA PIDs for the ECM are logging as N/A.
    Regards,
    The EFILive Team
    The [Check for Updates] option has been activated for both V7 and V8.
    The following versions (i.e. the previous public release) can be updated/patched automatically:
    • V7.5.36
    • V8.03.7
    Any versions installed before the previous public release will detect that an update is available, but the entire installation will need to be downloaded and installed.
    If you have installed any of the beta or RC updates (i.e. any installation of V7.5.37 or V8.3.8) then the [Check for Updates] option will not detect that a newer version is available.
    In that case, you should download and install the latest public release from this thread.
    Jan 2010
    Curious, V8 flashes fine. But with 7.5 I get this error about firmware even though it was updated. Was trying to flash an LS1B if it matters. I just happen to be more familiar with 7.5 and was looking for a specific issue when I came across this.
Name:	firmware boot block.jpg
Name:	7.5 version.JPG
    Quote Originally Posted by 1FastBrick View Post
    That is strange, it is also strange that no serial/license numbers showed up in the screen shot.
    This is what you should see...
    Is it possible that there is another device (AutoCal or other FlashScan) connected?
    Maybe the V8 software still has the V2 device connected and is preventing the V7 software from reading it.
    Jan 2010
    The license showed up, I blacked it out...Click image for larger version.
    I believe Only the The V7 tune was open. I only have one V2 no Auto Cal
    I was using a Bench top set up.
    Jan 2010
    Its is working correctly now. Click image for larger version.
Name:	V2 software version.JPG
ID:	23911 I have flashed a few versions of the same tune successfully with out issue in the V7 software.
    I think I ran into this before and it had something to do with needing to re-boot. Which I did not earlier after loading the software and updating firmware.
    Next Question. Regarding a full flash. If I full flash a PCM with a completely different calibration, Shouldn't it completely over write an existing calibration? Specifically the LS1B. I know E38 and E67 need to make sure they are compatible with the ECU.
    Yes you can full-flash any OS into an LS1 - but remember some LS1 controllers are 512KB and some are 1024KB and you can't mix/match the different memory sizes.
    And because the LS1 handles the transmission as well, you also need to be careful about flashing an automatic tune into a manual vehicle and vice-versa.
    Jan 2010
    The Memory size and auto/manual transmission I know and understand on these controllers.
    Lets use the 1024KB as the example. In the Past I was able to Full Flash one of these with Completely different Base tune with out issue. Recently I can not. The Cycle looks to complete normally but if you go back to read the PCM It still has the old File in it. Now if I change the Vin Number to the new Calibration's vin in the scan tool, It will flash Correctly.
    In this case both files happen to be of the same year. One was an 8.1L/ 4L80E 4x4 and I was flashing over it with a 5.3L 4L60E 2wd calibration. Full Flash was used. When I read it back out to verify it still had the 8.1L tune in it. But if I use the scan tool to change the Vin to the 5.3L VIN and then go back and do a Full flash it will take with out a problem.
    I also tried the reverse to see if it did the same thing. Does not take until I change the Vin.
    Try these for the example.
    How are you determining that the tune was not installed during the flash?
    I tried it here on a 1MB PCM with those two files and it all worked as expected.
    Jan 2010
    After flashing it, I read it back out to make sure the file took correctly. Maybe I need to remove and reinstall the software. It doesn't give any errors. I even read it out a second time to confirm.
    I appreciate you verifying it.
  1. September 2021, V8.3.8 RC2
    Last Post: September 22nd, 2021, 12:38 PM
  2. September 2021, V8.3.8 RC1
    Last Post: September 20th, 2021, 08:29 AM
  3. June 2021, V8.3.7 Public Release
    Last Post: August 6th, 2021, 01:58 AM
  4. May 2021, V8.3.6 Public Release - Update 1
    Last Post: May 27th, 2021, 05:10 PM
  5. Known issues with the September 2015 Public Pre-Release
    Last Post: September 11th, 2015, 09:46 AM
