Results 11 to 20 of 27
Thread: September 2021, V8.3.8 Public Release
  1. #11
    Jan 2010
    Ok, I completely removed EFI Live software. I then Shut down and restarted my computer. I Re Download EFI V8 and V7.5 from this thread. I then restarted the computer again. The issue continues. Even if I shut down and reopen V8 between flashes.
    Pay attention to the Vin number displayed. I attached them to these file names as well. I had the same issue with the other files I posted. It will Only Full Flash a new file If I change the vin number to that file. I forgot if you do a license check in V8 it will read the Vin Of the current file programed. Service number on PCM is 12589463. Bench Harness is from EFI connection. Let me know if I can provide any other information.
    06 GMC 5.3 Flex Fuel_3GTEC14Z96G161219.ctz
    3GNGK26G84G291431 2004, 8.1l, 4l85E, 4X4.ctz
Name:	Base file read.JPG
Name:	Full flash new file.JPG
Name:	Full Flash New file start.JPG
Name:	full flash new file completed.JPG
Name:	License check after Full Flash.JPG
Name:	8.1L Full Flash After Vin Swap.JPG
Name:	Full Flash after Vin swap complete.JPG
Name:	License check after Full Flash vin swap.JPG
  2. #12
    Again, I need to know how you are determining that the tune file was not flashed in?
    If you are basing it off of the VIN then that won't work since the VIN is not changed/updated when you flash a tune file - even during a full-flash.
    What you need to do is flash the tune in, read it back out and save it with a different name, then use the tune compare option to compare the tune file that was flashed v's the tune file that was just read back out.
    They should be the same. Although there may be a checksum or two that are different. That is because EFILive may automatically adjust some backup ETC (electronic throttle control) tables to ensure correct operation of the ETC system.
  3. #13
    Jan 2010
    I have also read it back out after doing a full flash. That's how I knew the file was not changing. here is an example
    LS1B_0000 Base read.ctz
    LS1B_0001 After Full Flash.ctz
  4. #14
    Jan 2010
    The 2 files are completely different and should not compare if it correctly flashed the other operating system during a full flash.
Name:	2004 8.1 file details.JPG
Name:	2006 5.3L file details.JPG
  5. #15
    Quote Originally Posted by 1FastBrick View Post
    These 2 files are completely different (different OS's even)... V8 compare sees them as different:
    Code:
    Calibration comparison summary:    Sep 28, 2021 06:22:28 PM
    Calibration Name:    C:\Users\joecar\Downloads\LS1B_0001 After Full Flash.ctz
    Controller:    LS1B
    Operating System:    12619623
    Alternate Name:    C:\Users\joecar\Downloads\LS1B_0000 Base read.ctz
    Controller:    LS1B
    Operating System:    12612114
    Description    Calibration    Status    Difference    Calibration    Alternate    Units
    Different    Seg 1    Operating System        12619623 ($BCE9)    12612114 ($EB92)
    Different    Seg 2    Engine Operation        12619625 ($66EF)    12612119 ($0265)
    Different    Seg 3    Engine Diagnostics        12591440 ($80FE)    12612669 ($A0E0)
    Different    Seg 4    Transmission Operation        12591457 ($EADE)    12578782 ($6E10)
    Different    Seg 5    Transmission Diagnostics        12606607 ($49ED)    12578793 ($ED78)
    Different    Seg 6    Fuel System        12591497 ($6CAB)    12612129 ($9ACB)
    Different    Seg 7    System        12591524 ($200A)    12578832 ($15BF)
    Different    Seg 8    Speedometer        12606732 ($7238)    12579002 ($02D9)
    Different    B0101    Main VE Table    Different from [0,0]..[18,19]
    Different    B0102    VE while Cranking    Different from [0,0]..[8,32]
    Different    B0104    Cylinder Volume        666    1013    cc
    Different    B0120    RPM Threshold For Airflow Calculation        4000    4150    rpm
    Different    B4901    Charge Temperature Blending    Different from [0,0]..[0,15]
    Different    B4902    Charge Temperature Filter    Different from [0,0]..[0,15]
    Different    B3201    Initial Fuel Prime    Different from [0,0]..[0,4]
    Different    B3202    Initial Fuel Prime Delay    Different from [0,0]..[0,15]
    Different    B3203    Initial Fuel Prime Timer    Different from [0,0]..[0,15]
    Different    B3204    Non Sequential First Fuel Pulse    Different from [0,0]..[0,15]
    Different    B3205    Non Sequential First Fuel Pulse Delay    Different from [0,0]..[0,4]
    Different    B3206    Non Sequential Second Fuel Pulse    Different from [0,0]..[0,6]
    Different    B3207    Non Sequential Second Fuel Pulse Delay    Different from [0,0]..[0,15]
    Different    B3604    Commanded Fuel When Cranking    Different from [0,0]..[16,18]
    Different    B3642    After-start Coolant Temp Enrichment    Different from [0,0]..[4,18]
    Different    B3662    After-start Enrichment Factor    Different from [0,0]..[0,16]
    Different    B3627    After-start Enrichment Decay Delay    Different from [0,0]..[4,18]
    Different    B3628    After-start Enrichment Decay Rate    Different from [0,0]..[4,14]
    Different    B3650    After-start Enrichment Decay Factor    Different from [0,0]..[4,18]
    Different    B3661    Restart Enrichment    Different from [15,10]..[18,20]
    Different    B3629    Park To Drive Enrichment    Different from [0,0]..[0,15]
    Different    B3630    Park to Drive Enrichment Decay Delay    Different from [0,0]..[0,15]
    Different    B3631    Park to Drive Enrichment Decay Rate    Different from [0,0]..[0,15]
    Different    H0101    Vehicle Speed Sensor Pulses per distance traveled        62958    68989    count/km
    Different    H0103    Differential ratio        3.730    4.100    factor
    Different    H0104    Trans Output Shaft Revs/distance traveled        1577.0323    1733.6250    rev/km
    Different Axis    H0108    ETC Speed Govern Threshold
    Different Axis    H0109    Maximum Vehicle Speed (Non ETC)
    Different Axis    H0110    Overspeed Timer (Non ETC)
    Different Axis    H0111    Maximum Vehicle Speed (With ETC)
    Different Axis    H0112    Overspeed Timer (With ETC)
    Different Axis    H0113    Speed Limiter Disable
  6. #16
    Jan 2010
    Which is why I don't under stand what's happening. As you saw in my other post after flashing, It was shown they were similar files and even made a comparison.
    Today when I try to compare the same 2 files in V7 it shows they are different. Even shows the warning that they are different and no comparison will be made.
Name:	todays comparison.JPG
    I will Admit I am still fumbling with V8 so I though I was doing something wrong But V7 says the same thing so it leaves me scratching my head.
  7. #17
    Do you happen to have "Test Flash" selected? If so, then nothing will get flashed, it will just go through the motions.
  8. #18
    Jan 2010
    No, I do not.
Name:	V8 Flash screen.JPG
  9. #19
    OK, let's get to the bottom of this. Can you please do the following:
    Read the PCM, save the file as "First_read.ctz" and once the read is complete, save a *.htx trace file from the EFILive Control Panel, call it "First_read.htx".
    Full-flash a different file, at the end switch off the ign. wait the required time and switch on the ignition again. Save another trace file, call it First_flash.htx.
    Read the PCM again, save the file as "Second_read.ctz" and once the read is complete, save a *.htx trace file from the EFILive Control Panel, call it "Second_read.htx".
    Then zip up the following five files:
    1. First_read.ctz
    2. First_read.htx
    3. The file that you flashed in.
    4. Second_read.ctz
    5. Second_read.htx
    Thanks.
    Hopefully I can figure out what is going wrong from that data.
    To save a *.htx trace file from the EFILive Control Panel, click the [Control Panel] button in the top right corner of the V8 main window.
  10. #20
    Jan 2010
    Thank you! I will try it right now.
  1. September 2021, V8.3.8 RC2
    Last Post: September 22nd, 2021, 01:38 PM
  2. September 2021, V8.3.8 RC1
    Last Post: September 20th, 2021, 09:29 AM
  3. June 2021, V8.3.7 Public Release
    Last Post: August 6th, 2021, 02:58 AM
  4. May 2021, V8.3.6 Public Release - Update 1
    Last Post: May 27th, 2021, 06:10 PM
  5. Known issues with the September 2015 Public Pre-Release
    Last Post: September 11th, 2015, 10:46 AM
