Results 1 to 6 of 6
Thread: Car Dies With A/C On
    Jun 2005
    Default Car Dies With A/C On
    Any tables to look towards for this issue? Car is tuned SD Custom OS3, with STFT's on. Car idles and runs perfect, however now in the summer with A/C compressor on when at idle, car will throw a 1514 Code Go into reduced engine mode and the car will die . If I clear all codes, turn A/C off, and restart, the car will run fine again.
    A/F is spot on, STFT's are 0 to -2. C6101 is raised, so don't think thats the problem. Any ideas? I tuned the VE in the winter when compressor was off, so maybe thats the issue, though don't think so b/c stft's are inline.
    Any help is appreciated.
    2000 Corvette Twin Turbo
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
    Oct 2005
    B4354?
    2014 VF SV LS3 Maloo.
    Jan 2005
    my AC died before i could figure this one out. I believe the problem to be not enough torque to drive the compressor. In watching many stock vehicles, as soon as you turn on the AC, the IAC starts moving then the compressor kicks in. You need more IAC action.
    Jun 2005
    Well being a vette we have no IAC, so either I play with B4354 alittle or possibly just raise my idle when A/C is on say 100RPM I am running stock idle tables with heads and cam. So I will move A/C in gear to 725 and A/C Park to 750 see if that remedies it, if not I will mess with B4354.
    Thanks guys Ideas always gets the brain going in the morning.
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
    Jan 2005
    I was under the impression vettes still required idle air control, the difference being the ETC adjusting the TB blade instead of an IAC motor. I'll take a closer look at it when I get my laptop back.
    Jun 2005
    Well I adjusted the Idle RPM's when A/C on up 100rpms and that took care of the issue. Car runs perfect again. Done deal.
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
  1. Car Dies with IAT plugged in
    By laughatrice in forum Gen III V8 Specific
    Last Post: June 10th, 2009, 06:26 PM
  2. 98 LS1 dies at idle
    By sdhager in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 06:23 AM
  3. RR dies
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 10th, 2007, 10:01 PM
  4. Car dies when I turn on the A/C
    By Powerhouse in forum Gen III V8 Specific
    Last Post: July 29th, 2007, 01:05 PM
  5. Car just dies
    By 1bar in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2006, 05:05 PM
