Results 1 to 5 of 5
Thread: $0312 Sub Function Not Supported or Invalid Format ($12)
    Oct 2021
    Default $0312 Sub Function Not Supported or Invalid Format ($12)
    Previous tuner loaded custom tunes to truck, now I am trying to adjust tunes and i am coming up with this error
    "$0312 Sub Function Not Supported or Invalid Format ($12)"
    Is this a result of previous tuner locking the tune?
    V3
    Firmware V3.00.070
    Bootblock V3.00.005
    V8
    Version 8.38
    here is trace file 20211025_171526_CMB_R.txt
    Your ECM has a CSP5 Custom OS in it, reading will be blocked unfortunately for you.
    Oct 2021
    So answer is dealer flash?
    Or is there another way, such as someone sending me the correct file.
    ECM Shows E/C S90170.02
    You should be fine to flash over the top once you get a suitable file (provided you are happy to lose the tune in there forever?)
    Oct 2021
    I see, I’ll see if I can come up with a stock file.
    I believe I may run a single tune and adjust accordingly so I don’t run into this issue again.
    Thanks!
  1. flashscan v2 error $0312
    By 07cummins in forum Diesel
    Last Post: January 22nd, 2019, 05:22 PM
  2. Error $0312
    By Bdirtymax in forum Black Box Logging
    Last Post: October 2nd, 2018, 08:10 AM
  3. CM2350B error $0312
    By modpcm in forum Cummins 6.7L
    Last Post: August 13th, 2018, 06:39 AM
  4. Error $0312
    By Road in forum FlashScan V2
    Last Post: February 25th, 2017, 02:31 AM
  5. error 0312
    By easymon in forum Cummins 5.9L
    Last Post: August 5th, 2012, 03:23 PM
