Results 1 to 9 of 9
Thread: 2020 High Output Base File needed Please
    Aug 2019
    Default 2020 High Output Base File needed Please
    CM2450B OS: 52200202 CI: 52401032AG
    This truck is high output with Aisin transmission.
    Aug 2019
    Thank you so much!
    Aug 2019
    Whistler is this file able to be converted to CSP5? I am still using V7.5. It shows that it isn't upgradeable.
    No, you're going to need 52.20.03.00
    Aug 2019
    Okay, that is the newer release.
    Yes it is, the CSP conversion for that OS was done July 2020 so Dodge may have even released more OS's since then (it's impossible to keep up with )
    Aug 2019
    Thank you so much!
  1. L9H Base PCM Tune Needed
    By wrench-head in forum Gen IV V8 Specific
    Last Post: January 13th, 2019, 12:56 PM
  2. 5500 Party Bus Stock Base File needed
    By comnrailpwr in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 27th, 2018, 07:33 AM
  3. 2012 C6 M6 Base Model - Need base file!
    By GR8GAME in forum Gen IV V8 Specific
    Last Post: April 4th, 2016, 03:44 AM
  4. base timing in gear vs high octane question
    By Kurtomac in forum Gen III V8 Specific
    Last Post: April 29th, 2009, 01:25 AM
