CM2450B OS: 52200202 CI: 52401032AG
This truck is high output with Aisin transmission.
Thank you so much!
Whistler is this file able to be converted to CSP5? I am still using V7.5. It shows that it isn't upgradeable.
No, you're going to need 52.20.03.00
Okay, that is the newer release.
Yes it is, the CSP conversion for that OS was done July 2020 so Dodge may have even released more OS's since then (it's impossible to keep up with )
52.20.03.00 - IA80012.07 52401032AH 2020 D2 3500 6.7L PCM AISIN.ctz
This should work.
Thank you so much!
