When might you post 1.9?
Thanks,
Bruce
Thanks,
Bruce
PowrMax Performance
100 mm PowrMAF
V7.1.9 went to beta test a few days ago.
A number of problems have been identified and are being fixed. It will go back out to beta test tonight. If all goes well it should be available (in pre release form) by Friday or worst case, some time this weekend.
whats new in 7.1.9 ?
The known issues listed here are fixed in V7.1.9:Originally Posted by JxxxOxxxE
http://www.efilive.com/forum/viewtopic.php?t=1317
Will this bug be fixed in this version?
http://www.efilive.com/forum/viewtop...er=asc&start=0
That issue is the highest priority reason for the V7.1.9 release.Originally Posted by launchn
It is listed in the known issues as:
"After reading or reflashing, some vehicles are left with DTC's that cannot be easily cleared."
It should probably have also should say that "...the vehicle cannot be started until those codes are cleared..."
Whether it will be fixed or not depends on the success/failure of the current round of beta testing.
