Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: No communication with PCM
    Jan 2007
    Yes it is mate. I have it hooked up to a bench harness and power supply
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jan 2007
    HI Joe...
    Finally getting back to this.
    this is the text
    17:18:37.649: EFILive V7.5 Version V7.5.43 (Build 473)
    17:18:39.983: Ready.
    17:18:56.517: Scanning for EFILive FlashScan V1 USB
    17:18:56.549: Autodetect interface ...
    17:18:56.564: Interface firmware version: 1.2.17
    17:18:56.564: Connection to [FSP] interface is OK
    17:18:56.580: Current protocol set to: "SAE J1850 VPW"
    17:18:56.580: Autodetect PCM...
    17:18:57.610: PCM not detected.
    17:18:57.626: Interface firmware model: FSP
    17:18:57.626: Interface firmware version: 1.2.17
    17:18:57.641: Interface firmware date: Jan 18, 2005
    17:18:57.662: FlashScan serial number: 003562844266
    17:18:58.355: Validating PIDs...
    17:18:59.371: Initialising PIDs...
    17:18:59.371: Initialising Modules...
    17:18:59.387: Ready.
    Any thoughts?
    Howard
    DUCT TAPE.
    Jan 2007
    Fixed.
    went over the RR header with a magnifying glass and a meter. found a crack/break in one of the tracks where its soldered to the PCB
    Howard
    DUCT TAPE.
    Howard,
    Glad you found it. Did you apply solder to the pcb track to fix it.
    Post a pic.
    Jan 2007
    Yes mate….sure did ��
    Reckon the pressure of the USB cable on the on board USB socket was twisting the RR header which cracked the track.
    Howard
    DUCT TAPE.
    Jan 2007
Name:	RR header.jpg
Name:	RR header cracks.jpg
    Howard
    DUCT TAPE.
    Dec 2016
    Just a tip for you guys who solder small distant spaces like this as well as micros. Solder all 4 corners so the device won't move in the next step. Solder/short the entire connection, do it fast when soldering a micro and let it cool. Heat and drag solder wick soaked in rosin/flux across the terminals to suck up all the extra solder. Practice on something you don't care about if unsure.
    When finished, it will look like a machine soldered it.
  1. E39 ECU/PCM lost communication with SIDI VE V6
    By 3L SIDI in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: September 8th, 2013, 01:48 PM
  2. No Communication After Reflash?
    By Yukon 400 in forum Custom Operating Systems
    Last Post: October 22nd, 2008, 10:18 AM
  3. no communication w/ roadrunner...
    By rubbersidedown in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 4th, 2008, 12:42 AM
  4. Sometimes communication hangs
    By Ira in forum FlashScan V2 BB Logging
    Last Post: January 2nd, 2008, 09:29 AM
