Results 1 to 5 of 5
Thread: external ad setup
    Dec 2018
    Default external ad setup
    so Id like to setup an external analog input but do not know where to start. I understand that there is a calc_pids.txt? I am using a flashscan v3 and I cant seem to figure out how to enable external input.
    Which wideband do you have...?
    As far as I can tell, looks like V3 requires wideband to be connected via serial comm or CAN (in the case of AEM -0333/0334).
    More info:
    https://service.efilive.com/kb/artic...g-flashscan-v3
    https://service.efilive.com/kb/articles/pin-assignments
    https://service.efilive.com/kb/artic...-specification
    Let me check and get back to you.
    Aug 2018
    I have the same question for my Ballenger AFR500 V2, it only has analog output.
    The Pin assignments article listed above say the are for serial rx-tx and tx-rx inputs, nothing mentioned about analog.
    FSV3 does not have analog inputs.
    The Ballenger should have CAN bus and/or serial comm connection ability, FSV3 will be able to connect to it either way.
    Post the user manual pdf for the Ballenger.
    Aug 2018
    Thanks for the reply
    I know their next version has will work: AFR 500CAN
  1. Using external sensors with V2
    By jordylee18 in forum FlashScan V2
    Last Post: June 23rd, 2013, 03:13 PM
  2. Replies: 13
    Last Post: July 14th, 2012, 03:07 AM
  3. HELP! No external voltage!
    By gotabav in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2008, 10:52 PM
  4. External input
    By heavymetals in forum External A/D inputs
    Last Post: May 2nd, 2006, 04:44 AM
