Results 1 to 5 of 5
Thread: 3.0 duramax
    Jan 2011
    Default 3.0 duramax
    Hello,
    Since gm uses the E98 in older trucks, will efilive support the E98 found in the newer fullsize trucks used with the 3.0 duramax?
    Thanks,
    Matt Derks
    www.derkscustomcars.com
    It is not an E98, it is an E46 which unfortunately uses GM's new security of digital signing of the calibrations, no support is the likely outcome.
    Jan 2011
    Well, my mistake..
    Sent from my XP8800 using Tapatalk
    Thanks,
    Matt Derks
    Jan 2023
    It isnt, but it is based off the same conti0100 firmware/software. Someone with mapping experience should be able to do this fairly easy. The problem is flashing it successfully/unlocking the 5 bye seedkey. Currently 5 possible options that I have found.
    1, Bruteforce attack, takes up to 7 days for seed key.
    2, EMI fault injection to accept seed pass(colin flynn) PicoEmp
    3, A certain GM software that doesnt require SPS
    4, SPI/Lin bus reading/programming through secondary chip, possible but takes smarter minds than me.
    5 Aftermarket ECU, such as the mercury marine 3.0L boat motor, ECU is $1200,
    https://www.mercurymarine.com/en/us/...30l-150-270hp/
    Dont know if the pin harness is the same, cant find too much info on it.
    This project really needs a team to do it, I have got pretty far with everything but am currently stuck at mapping the bin files.
    Mar 2022
    The E46 can now be unlocked. Hopefully someone can map out the tune and maybe Efilive will at least give us the ability to flash them. https://controllerdiagnostics.com/pr...cation-service
  1. 2017 Duramax
    By SPi in forum General (Diesel)
    Last Post: April 15th, 2018, 06:01 PM
  2. 4.5L duramax
    By KillaKustomKables in forum General (Diesel)
    Last Post: March 18th, 2018, 12:19 PM
  3. 2017 duramax
    By djv86 in forum General (Diesel)
    Last Post: June 24th, 2016, 10:48 PM
  4. duramax lmm help
    By ticketme in forum Diesel
    Last Post: May 27th, 2016, 01:06 AM
