Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Oppisite effect
  1. #11
    Also, when you did AutoVE did you make sure that the MAF is failed and trims are disabled.
    Also, btw, increasing the IFR will cause the ECM to fire the injectors for a shorter time.
    Did you populate the injector tables with data for the new injectors...?
    See what Highlander said above.
    +1 what statesman said, when fueling doesn't respond to airmass changes, something is really wrong.
  2. #12
    Apr 2007
    Quote Originally Posted by Highlander View Post
    make sure your injector pw at idle is not less than b4003. otherwise it will not pull fuel after reaching this min limit.
    Do you mean B4003 vs the lower RPM's on B4001? B4003 is .8 and with the 60's B4001 is 8.7's.
    Is that what you meant?
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
  3. #13
    Jul 2003
    I meant: make sure your injector pulsewidth at idle is not less than b4003. otherwise it will not pull fuel after reaching this min limit.
  1. LS1B VE Tuning No Effect
    By macanic21 in forum Gen III V8 Specific
    Last Post: December 9th, 2019, 12:16 AM
  2. PE throttle threshold changes have no effect
    By MadMaxHSV in forum Gen IV V8 Specific
    Last Post: June 9th, 2011, 04:36 AM
  3. Ported TB effect on VE?
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: April 22nd, 2008, 01:02 AM
  4. Tuning VE with RR...no effect
    By Wichita Dyno in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 6th, 2007, 04:18 AM
  5. Temp effect on AFR?
    By 98WS6_JPM in forum General (Petrol, Gas, Ethanol)
    Last Post: March 7th, 2006, 04:49 PM
