Results 1 to 10 of 11
Thread: Trouble reading 6L80 tune
    Apr 2021
    Default Trouble reading 6L80 tune
    I have a stand alone 6L80 and am having issues uploading the tune,,,If I open V8, go to tune, then auto detect it correctly detects the T43 controller, then when I hit read it goes through the steps all the way to "read, please wait" then I get a $0101 script stopped no data....
    The transmission is operating only I desperately need to get in and see about tuning the shift points
    Edit, if I use V7.5 tune it gets to the same point, reading then after 20 minutes of the little green circle going around with the progress bar staying blank I gave up.
    I wounder if I should try to load a 6L80 tune and see what happens???
    A TCM in 'stand alone' would need a CAN termination if there is no other modules (normally that would be the ECM), do you have that?
    Apr 2021
    I will have to check with the stand alone folks, I would ASSUME they put a CAN termination in there because it would never have a ECM or BCM in line.
    Also I will ohm out the termination and see if I can detect the resistor.
    EDIT, no CAN resistor, the circuit reads open, I will try and rig something up.
    Apr 2021
    So I added a CAN termination resistor (55 ohm, close enough) and still no go on reading data
    Apr 2021
    I found some tunes, I wonder if I can do any damage (brick the TCM) by trying to load one?
    Dec 2016
    IMO if you can't read it reliably, no way would I attempt a write. CAN termination should be 120 ohms.
    Apr 2021
    I can certainly try 120 ohms, but some systems have more than one so 60 of so should still work, will give it a shot in the AM
    Dec 2016
    I haven't tried a T43 since it is internal. My T87 stuff wouldn't read with efilive nor hpt but I could read it with my AVT852 which was interesting. The 120 ohm termination resistor was the trick. You probably already know but I will post for others that might stumble across the thread. The termination resistor is connected across CAN+ and CAN-
    Apr 2021
    It was pointed out by the great folks at Zero Gravity that the 2650 controller can be programmed for up to two CAN termination resistors, I tried one and two with no success.
    It seems to me because the V2 recognizes the correct TCM and it appears the password goes through alright that the communications would not be suspect, but of course I know nothing
    I am going out on a drive today so I have a little time on this before coming home and trying to load a tune in the TCM just in case I brick it, I suspect something is up with the tune itself, but of course again I know nothing but have to try something.
    Apr 2021
    Well after fudging the TPS calibration it shifts pretty dang good, Zero Gravity says they use HP Tuners so it is possible the EFILive V2 just will not be able to work in stand alone mode, at any rate I am pretty happy as it is without spending another $400 for an HP Tuners setup.
  1. trouble reading pids
    By nick123 in forum Petrol / Gas
    Last Post: September 10th, 2019, 10:21 PM
  2. 98 Vortec trouble reading with 7.5..but v8 worked?
    By Dmaxink in forum Vortec V6/V8 Specific
    Last Post: December 21st, 2010, 10:50 AM
  3. Replies: 3
    Last Post: August 27th, 2010, 02:24 AM
  4. Trouble reading PCM tuned earlier with HPT?
    By Mr. P. in forum General
    Last Post: December 11th, 2007, 04:26 AM
