Results 1 to 10 of 10
Thread: Engine braking
    Mar 2014
    Default Engine braking
    Hello,
    Hope all well.
    I would like to increase my engine braking as trying to fine tune.
    I have efilive and understand may be the throttle follower cracker tables
    When if accelerating and i come off throttle i want to increase that braking a bit more as having to brake harder at the moment but dont want severe engine braking if shifting up through gears, so is this the delay or decayNewInj_0006.ctz?
    What exactly should i try?
    would like a bit more less cruise control in all speeds but more braking at higher speeds after a delay.
    Have attached my latest tune COS3
    Tried posting in LS1techbut no replies so far..
    gavin
    Feb 2006
    Hi Gav,
    I’ll spark up my laptop later on and have a look at your tune file, throttle follower affects overrun (so cruise effect), you can also play with DFCO to affect engine braking.
    Rgds
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    Try retarding the spark table(s) at loads (g/cyl) correspondin to closed throttle.
    Also, if you have AT, set the TCC to remain locked on closed throttle coast.
    Feb 2006
    Gav, if you get too close to zero then you’ll pop n bang on overrun (a giggle for a while ;-))
    Jim
    Mar 2014
    Ahhh wasnt notified anyone replied. Thanks though both.
    Will look into it abit more
    Gav
    Mar 2014
    Hi,
    How much should I retard the timing? Running around 37 in those overrun areas atm, gonna try 30? Or do I need a lot more?
    Gav
    It's an M6 btw
    Feb 2006
    Quote Originally Posted by Gav View Post
    Hi,
    Gav
    It's an M6 btw
    Hi Gav,
    I
    Feb 2006
    Er, where did my post go!
    10 degrees
    Short version!
    Feb 2006
    10 degrees will get you the pops n bangs (sorry, didn’t read the thread as it popped up,on my iPhone!)
    Mar 2014
    Hi,
    Reduced to 30 degrees in those areas helped.
    No pops yet though....
    Gav
  1. Replies: 2
    Last Post: January 23rd, 2011, 09:57 AM
  2. Engine braking in DFCO
    By Wmija in forum Tuning For Economy
    Last Post: October 20th, 2009, 01:21 PM
  3. Engine braking
    By Rich in forum Gen III V8 Specific
    Last Post: December 26th, 2008, 08:48 PM
  4. A4 Engine Braking
    By neil in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2006, 03:42 PM
