Results 1 to 1 of 1
Thread: November 2021, V8.3.12 Public Release - Update 4
    Default November 2021, V8.3.12 Public Release - Update 4
    Attention:
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V7 software: V7.5.41 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.12 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.080 (Nov 22, 2021), Boot Block: V3.00.005 (Oct 20, 2020)
    • FlashScan/AutoCal V2 Firmware: V2.08.182 (Nov 11, 2021), Boot Block: V2.08.009 (Feb 27, 2021)
    Download here:
    Known Issues:
    Issue #1: Importing JTAG E86B files may result in a Boot Software segment checksum error.
    Workaround: None. Don't flash imported files with checksum errors. Don't use the EFILive software to correct checksum errors for the E86B imported files as that does not fix the underlying cause of the checksum error - it just masks the error(s) and causes additional problems.
    Issue #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Regards,
    The EFILive Team
  1. November 2021, V8.3.11 Public Release - Update 3
    Last Post: November 3rd, 2021, 12:05 PM
  2. October 2021, V8.3.10 Public Release - Update 2
    Last Post: October 27th, 2021, 10:41 AM
  3. September 2021, V8.3.8 Public Release
    Last Post: October 4th, 2021, 01:22 PM
  4. May 2021, V8.3.6 Public Release - Update 1
    Last Post: May 27th, 2021, 06:10 PM
  5. Current Public Release November 2020
    By cindy@efilive in forum Software Updates and Installation Help
    Last Post: January 26th, 2021, 06:26 AM
