Results 1 to 9 of 9
Thread: Tune unlocking
    Nov 2008
    Default Tune unlocking
    I trued to use the search function but no such luck. I have a pair of LMM's both tuned by IdahoRob fromerly of ATP. Well I just put bigger tires on both and have no way to adjust the speedometer as the tunes are locked. Is there a way around this? I'd hate to buy new tunes as these work amazing.
    Martin
    2008 GMC Sierra Crew Cab 4X4 334 hp and 599 ft/lbs on 24 Aug 2008 at Meridian Motor Sports Meridian Idaho.
    Jan 2011
    Yes if I recall right, V8 will unlock it for you but it can take days.
    Sent from my XP8800 using Tapatalk
    Thanks,
    Matt Derks
    www.derkscustomcars.com
    Jan 2011
    If that doesn't work, I have an other program that can unlock it as well..with V8 it will over write the file with another tune. Just ask Idaho Bob for an adjustment or the unlock key.
    Thanks,
    Matt Derks
    Oct 2010
    Try and read it out of ecm..
    Sent from my SM-G892A using Tapatalk
    May 2018
    No one will unlock the files. They are the property of the tuner. Atp will not touch these times as the epa tied his hands a long time ago.
    You can read the ECM out in raw binary and remove the lock coding if you desire to use those files yourself. Otherwise, have someone else tune it again.
    Locked files can be flashed over with someone else's filea
    Sent from my KB2007 using Tapatalk
    Nov 2008
    I have no idea how to get ahold of him any more since he closed up shop. I moved to Alaska and lost touch unfortunately
    Sep 2019
    Quote Originally Posted by usafracer View Post
    Hey USAfracer, were you able to figure this out? I
    Jul 2016
    Martin
    I'm in the same boat as you are, I went down in tires size significantly, with plans to remove my lift kit. I've resigned myself to either learn to accept the speedo being off or buy a new one from someone that still does non epa compliant tunes, if you can find someone.
    Jan 2011
    I can help, send me your files. Mderks@gmail.com we'll discuss it there
    Thanks,
    Matt Derks
  1. Unlocking autocal
    By Blackice in forum AutoCal
    Last Post: November 11th, 2016, 09:27 AM
  2. Replies: 5
    Last Post: May 16th, 2014, 12:32 PM
  3. Unlocking pcm
    By carter01 in forum Gen III V8 Specific
    Last Post: May 23rd, 2011, 12:36 PM
  4. Unlocking PCM
    By mjp80538 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 16th, 2006, 02:56 PM
  5. Pcm Unlocking
    By JCA in forum Tips and tricks
    Last Post: October 19th, 2006, 03:22 AM
