Results 1 to 8 of 8
Thread: 2007 Chevy Suburban DOD/AFM Disable+ Tune
    Mar 2014
    Default 2007 Chevy Suburban DOD/AFM Disable+ Tune
    Good morning
    The wife and I purchased a 07 Chevy Suburban with the 5.3l V8. I would like to put a stage 1 tune and disable DOD/AFM. I am able to use a EFI live tuner from our shop. I have never used efi live . how does this work. is there a way to purchase a a stage 1
    tune for my SUV ?
    or can I just download my SUV stock tune and adjust parameters, and disable DOD? On my other car when I purchased a tuner for it, it also came with 4 generic tunes from tuner manufacturer. does efi work same way?
    thank you in advance
    read the ECM and TCM tunes off your truck with the EFI Live and save them.
    You can adjust the parameters needed to get the results you want.
    Send me a Private message.
    Mar 2014
    is there a post or somewhere to learn or read which parameter needed to adjust on TCM, ECM? for now i want to turn off AFM/DOD . I am getting a S&B air intake however they are on B/O. planning to do full exhaust with headers. depending on how hard it is to remove pass header.
    Jan 2020
    Disabling DoD is not that difficult.
    Read ECM, save file, open file, scroll down to the DoD folder, adjust calibration values accordingly. Save file again, with a different name, license ECM, then cal flash ECM.
    For DOD disable
    B0921 Change to NO
    B0961 Change all to DISABLE
    Mar 2014
    E38_0000_AFM_OFF.ctzE38_0000Stock_tune12-12-21.ctzT42_0000stocktune_12-12-21.ctz
    here are my stock tunes plus one with DOD disabled. however I m trying to figure out how to to load back to PCM?
    Jan 2020
    Open V8 scan and Tune
    F3
    auto detect
    F3, find and open the file that you made
    F6, license the controller, follow the prompts, then flash
    Just for fun.. Here is a Script to run on a E38 ECM to disable DOD/AFM
    Save this file to this Location on your PC
    Documents\EFILive\V7.5\User Configuration\Scripts
    E38_DOD_AFM_Disable.txt
    Read your tune off the ECM and save it
    Open your tune
    Press CTRL+P to run a script
    Click open at the bottom left and find this file name to double click on it
    Bottom left click Run
    Click Close
    Save file with a new file name
    Cal-Flash the tune and your done
  1. Disable AFM/DOD and VVT
    By JoshH in forum E37, E38 & E67 PFI ECM's
    Last Post: June 27th, 2016, 06:34 AM
  2. AFM/DoD controls?
    By 06black in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 22nd, 2016, 03:21 PM
  3. Need tune 2007 Suburban L76
    By Maxirat427 in forum Gen IV V8 Specific
    Last Post: February 20th, 2016, 06:11 AM
  4. E38 Boost + AFM/DOD
    By NateD4 in forum Custom Operating Systems
    Last Post: December 13th, 2011, 11:04 AM
  5. Using Flashscan to tune 07 trucks w/DOD & AFM
    By eallanboggs in forum Gen III V8 Specific
    Last Post: December 27th, 2006, 08:17 AM
