Results 1 to 2 of 2
Thread: E38 Throttle responce Maps
    Mar 2014
    Default E38 Throttle responce Maps
    i have been playing with Efi live. the TP stock setting are way off .example when i press throttle 80% it is actually 60% at 40% its only 16%
    that is huge difference. on my other car DBW map i did change it and it made huge difference. however i only changed higher TP values on small TP like 10,15,20% i left stock because it is too sensitive.
    Quote Originally Posted by 01S10AD View Post
    There is going to be a difference.
    Think about if your not touching the TP that is going to be 0%. But the engine is idling so the ETC is actually open about 15%. At some point they will cross over and its about 50-60%.
    And make sure your logging the correct PIDs.
  1. Express Van E78 sluggish cruise throttle responce
    By curtistdc in forum E78, E83, E84 PFI ECM's
    Last Post: July 22nd, 2021, 04:10 AM
  2. LS1b 12606807 OS- what maps can limit throttle blade position
    By Jetmech442 in forum Gen III V8 Specific
    Last Post: August 1st, 2014, 10:32 AM
  3. vy v6 no bcm responce
    By Lucky in forum EFILive V4
    Last Post: December 10th, 2013, 10:09 PM
  4. E38 - Throttle Cut / Throttle Blip
    By Z06-GT3 in forum Lounge
    Last Post: June 14th, 2011, 04:16 AM
  5. E38 SD PIDs and MAPs
    By JezzaB in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 02:10 PM
