Results 1 to 10 of 16
Thread: December 2021, V8.3.14 Public Release - Update 6
    Default December 2021, V8.3.14 Public Release - Update 6
    Attention:
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V7 software: V7.5.42 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.14 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.083 (Dec 08, 2021), Boot Block: V3.00.005 (Oct 20, 2020)
    • FlashScan/AutoCal V2 Firmware: V2.08.183 (Dec 08, 2021), Boot Block: V2.08.009 (Feb 27, 2021)
    Download here:
    Known Issues:
    Issue #1: Importing JTAG E86B files may result in a Boot Software segment checksum error.
    Workaround: None. Don't flash imported files with checksum errors. Don't use the EFILive software to correct checksum errors for the E86B imported files as that does not fix the underlying cause of the checksum error - it just masks the error(s) and causes additional problems.
    Issue #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Regards,
    The EFILive Team
    Found a problem in this and the previous update (only two new ones I tried). In the V8 scan/tune when using the scan tab opening log files, if you have other programs open like chrome or V7.5. Everytime a window pops up in the V8 scan software were you have to click ok/continue ect. It will minimize V8 and switch over to chrome or the program tab, not sure if it's just on my end or what?
    04 LB7
    2010 LMM
    2015 LML
    Quote Originally Posted by rcr1978 View Post
    Does it minimize before you click [OK] or after you click [OK]?
    After clicking ok/continue
    04 LB7
    2010 LMM
    2015 LML
    Can you post a screen shot prior to clicking OK/Continue?
    And then post a screen shot after clicking OK/Continue?
    Instructions for how do make screenshots (Windows 8, 10 and 11):
    https://support.microsoft.com/en-us/...reen=windows-8
    [attach=config]23985Click image for larger version.
Name:	Screenshot 2021-12-13 194450.png
    It does it for both of these.
Name:	Screenshot 2021-12-13 194529.png
    04 LB7
    2010 LMM
    2015 LML
Name:	Screenshot 2021-12-13 195425.png
    Here is the after clicking ok, defaults to whatever was opened prior.
    04 LB7
    2010 LMM
    2015 LML
    That is very strange. I can't get that to happen on any of our test systems here. We have also not had anyone else report that strange behavior.
    I did some searching online and found this, which may help you test/change some settings in Windows to prevent that problem.
    https://www.askvg.com/fix-apps-and-p...in-windows-10/
    Thanks Paul, I will give these try. Sorry to bother with windows created problems, it was something new and only appeared to happen the EFILive stuff.
    04 LB7
    2010 LMM
    2015 LML
    I tried the above things that didn't appear to change anything, I did find something that helped. If I actualy minimize the other open programs using the top right of the screen instead of just clicking over from tab to tab in the task bar. The V8 software functioned like normal and did not minimize when clicking ok/continue of the windows that pop up. Guess for now I will just keep going with that option, kinda weird.
    04 LB7
    2010 LMM
    2015 LML
  1. November 2021, V8.3.13 Public Release - Update 5
    Last Post: December 2nd, 2021, 04:27 PM
  2. November 2021, V8.3.12 Public Release - Update 4
    Last Post: November 21st, 2021, 11:19 AM
  3. November 2021, V8.3.11 Public Release - Update 3
    Last Post: November 3rd, 2021, 12:05 PM
  4. October 2021, V8.3.10 Public Release - Update 2
    Last Post: October 27th, 2021, 10:41 AM
  5. May 2021, V8.3.6 Public Release - Update 1
    Last Post: May 27th, 2021, 06:10 PM
