Results 1 to 7 of 7
Thread: VAT Relink E38
    Junior Member hsv084's Avatar
    Jan 2010
    Default VAT Relink E38
    Hi All,
    I have just replaced my E38 PCM in my Series 2 VF Commodore with a PCM with a matching Service Number.
    I was successful in doing a full flash and VIN update but have not been able to do a VAT relink.
    I car appears to be in an immobilized state and won't crank in combination with the antitheft light being up on the dash.
    Is there any tricks to the VAT relearn on the later Holden vehicles. Ignition cycles set to Zero also.
    If you want more inches stroke it
    Try writing the VIN again using the scantool, and then try the VAT relink again.
    Jan 2010
    Hi Joecar,
    I have just returned from holidays and attempted you suggestion with no luck.
    I think the issue maybe that efilive requires the ignition to remain ON for 10 mins for a CAN Bus vehicle before powering down.
    As my VF Commodore has a push button start it turns the ignition by itself after about 3 minutes, Not making the required 10 mins.
    Any suggested work around for this?
    Regards Jeff
    Dec 2016
    bench harness and good stable regulated power supply
    Jan 2010
    Quote Originally Posted by In-Tech View Post
    Unfortunately that isn't an option for me unless I pull the bcm and pcm out of the car and send it away.
    Open to any other suggestions. Is their away to extend the ignition on time of a push button start vehicle via efi live?
    Can you access the PCM harness connector and jumper power to the right pin (while PCM is still plugged in)...?
    You can change the ECM's relearn timer value from 10 mins to 1 min if you want, that is in the tune.
  1. Vat relink not working code $33
    By cumminsDK in forum General (Diesel)
    Last Post: February 26th, 2012, 11:10 AM
  2. VAT relink feature
    By killerbee in forum Duramax LLY
    Last Post: December 30th, 2011, 01:13 PM
  3. Do I need to do a VAT Relink ???
    By Ninety8C5 in forum Gen III V8 Specific
    Last Post: May 27th, 2008, 01:44 AM
  4. VAT Relink
    By Biggsy in forum Gen III V8 Specific
    Last Post: October 10th, 2007, 08:40 PM
  5. Change Vin # and VAT relink
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 23rd, 2007, 12:14 PM
Tags for this Thread
