Results 11 to 20 of 23
Thread: T-42 stock tune for OS 24252617
  1. #11
    Jul 2004
    Quote Originally Posted by In-Tech View Post
    I don't think you can brick it. You will have to write all 4 modules though, I've never checked with efilive stuff though, sry.
    Do you mean "full flash"?
  2. #12
    Jul 2004
    Okay, after further research here on the forum it appears I can't flash my old T-42 file to a newer module with a different OS. Can anyone offer any options here? Not sure how to find a T-42 module (new) with the older OS on it. Of course, since I have tried to flash the new module (that, when ordered was supposed to be correct for a 2008 Silverado 5.3) they won't take the module back.
  3. #13
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Welp... It seems I was wrong about the T42's not having the same risks or restrictions regarding changing the OS. I dug out one I had laying around that came out of an 05 Cobalt and tried flashing a 2007 MY calibration into it using TIS2000 and my Tech2. Seemed to go fine until the end, where I got an error and an option to retry, same error after retrying, and now it seems to be a vegetable.
    I think the best suggestion I can offer to get the right module would be to look at the 'SERV NO' on the label and look for one with the same number.
  4. #14
    Jul 2004
    Quote Originally Posted by ChipsByAl View Post
    You can refer to https://tis2web.service.gm.com/tis2web with the VIN from your vehicle and see what the correct calibrations are. Or if its a project vehicle, you can use the VIN from the ECM (if it is correct!).
    Al
    Thanks, I put in my VIN and it gives me the correct OS, which is what is in my tune file.
  5. #15
    Jul 2004
    I'm confused, this is the original module from the truck: Click image for larger version.
Name:	my original module.jpg
    This is the new module, which the part number matches from several sources for my truck:Click image for larger version.
Name:	new module.jpg
  6. #16
    Jan 2006
    Interesting.... So you read the tune out of your original, SERV NO 242423918052, and that calibration matches what TIS says is correct for your VIN, but the SERV NO for the new module crosses to your truck? When you entered your VIN in TIS, did it ask you for a module part number after you selected the TCM? Sometimes, such as with the LBZ/LMM Duramax, where you could have an A40, A42 or A50 TCM, you get something like this to select the module you're programming:
  7. #17
    Jul 2004
    Quote Originally Posted by Cougar281 View Post
    No, it gave me a pulldown for TCM, ECM, BCM, etc. but after I selected the TCM option it showed me the correct number, which matches my module. Everything I pull up on rockauto, gmparts, etc. all cross to the module I was sold.
  8. #18
    Jan 2006
    I'm not sure what happened last time I tried to program the T42, but I was able to recover it with EFILive and its original calibration, and I was just able to flash a 2008 Silverado 5.3 VIN calibration into it with TIS2000. It's possible that the replacement TCM that you have might be able to be programmed with the proper calibration for your truck using TIS2WEB (or TIS2000 depending on when your truck was built).
    How does the attached tune look compared to your original tune?
    T42_2008Silverado_5.3.ctz/
  9. #19
    Jul 2004
    This is from your tune:
    Operating System 24239927 $093DE5E2
    System 24240382 $813C37A9
    Transmission Operation 24245713 $107A85A7
    Transmission Diagnostics 24241986 $AECDB668
    This is from the tune I read from my module:
    System 24240383 $9A3622C3
    Transmission Operation 24245712 $3DDEE06B
    The operating systems are the same, of course the serial #, boot block, calibration I.D. and BCC are different.
    I see your point, do I have to have a TECH 2 to change the new module to suit my truck?
  10. #20
    Jan 2006
    I'm not positive, but yes, it's possible you might need a tech 2, MDI or MDI 2 and SPS to get the new module properly programmed, unless EFILive can override the mismatch and allow the flash. Hopefully Paul or Ross will chime in.
    Sent from my Pixel 5 using Tapatalk
  1. Replies: 14
    Last Post: November 14th, 2017, 04:10 PM
  2. 2006 Corvette stock tune, not so stock?
    By RecMech in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2014, 07:31 AM
  3. 2014 Corvette Stingray Stock Tune VS ProCharger's Tune (comparison)
    By n8dogg in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 10th, 2014, 02:36 AM
  4. Replies: 6
    Last Post: October 23rd, 2013, 04:27 PM
  5. Replies: 10
    Last Post: July 7th, 2012, 07:52 AM
