Results 1 to 4 of 4
Thread: LMM Segments OS 12628594 07.5
    Jan 2011
    Default LMM Segments OS 12628594 07.5
    I have an odd ball here, I looked up the OS and Segments on GM TIS, I have a hard time finding the proper segments.
    The segments I need I can only find in a 12617103 OS and they can't be swapped out. The ones that I am looking for are
    Speedo 12628797 or 12617137
    System 12643813,12628787 or 12617127
    Matt
    Thanks,
    Matt Derks
    www.derkscustomcars.com
    Jun 2011
    I'm no help but as long as you have the correct OS base file you can just do a CAL flash and none of the segments will change. This doesn't help if you need to full flash for other reasons though.
    Sent from my SM-G970U using Tapatalk
    Dec 2023
    Matt, did you ever have any luck finding a tune with those segments?
    I am looking for the same numbers
    OS 12628594
    Speedo 12628797
    System 12643813
    Engine operation 12634941
    Thanks,
    Jeff
    Jan 2011
    Jeff, got them all, I have been building a nice collection, email me, matt@derkscustomcars.com and i'll send them over
    Thanks,
    Matt Derks
  1. LMM OS 12628594 (NQG) Option
    By kidturbo in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 24th, 2019, 11:23 PM
  2. LMM OS 12628594 boost tables
    By GMPX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 28th, 2010, 08:23 AM
  3. LMM 12628594 calz update
    Last Post: February 3rd, 2010, 04:22 PM
