In your calc_pids.txt you have to do something like this:
Code:
# Add slot definitions here
*CLC-00-600
None 0 64 .0 "lookup({GM.DYNAIR}, 0,0, 4,4, 8,12, 12,30, 16,36, 20,40, 24,44, 28,50, 32,54, 36,64)"
but put your own DYNAIR values in the lookup pairs;
and then
Code:
CALC.CLMODE F600 CLC-00-600 None Loop "Closed Loop Mode"
