Results 1 to 10 of 11
Thread: Returning and starting tuning in Semi open loop SD mode
    Jun 2005
    Default Returning and starting tuning in Semi open loop SD mode
    I have my car pretty well tuned in. I am wondering is ther something that has to be changed to return to or to start tuning in semi open loop SD mode? I don't remember back that far what setting I might have changed to start tuning?
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Oct 2004
    To go to Semi-Open Loop just set the AFR's in the B3647 table to EQ Ratio of 1.00 or copy and paste the value from the B3601 table (if your OS file has it)
    Andrew
    EFILive Crew
    Jun 2005
    I realize that, I was wondering if I have to change any limits to activate or deactivate anything before or after I tune?
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Oct 2004
    Don't think so. Semi-Open Loop is coded to enable when the commanded AFR is equal to EQ Ratio 1.00. You should notice the Short Term Fuel Trims activate under those conditions (if you log them of course).
    Andrew
    EFILive Crew
    Sep 2003
    What about closed loop enable temp?
    Oct 2004
    Semi-Open Loop is specific to EFILive Custom OS V3 & V5. You can enable Closed Loop also, but that is not what is referred to in this thread
    Andrew
    EFILive Crew
    Sep 2003
    Question
    Yes I realized that, but I thought if you enabled closed loop but disabled longterm trims in Cos 3 & 5 it would be only short terms active when 14.63 (stoich) was commanded in B3647?
    Otherwise when tuning your ve then you are always getting corrections for STFTs when you dont want them?
    How do you turn off STFT when you are tuning VE then?
    Oct 2004
    Enabling Closed Loop but disabling Long Term Trims will use STFT only - you are right there. But, so does just using Semi-Open Loop.
    In the V3/V5 Custom OS you disable STFT by commanding something other than 14.63:1, like 14.7:1 for example. That way the STFT (Semi-Open Loop) is not enabled.
    Or perhaps I'm misunderstanding?
    Andrew
    EFILive Crew
    Dec 2004
    Quote Originally Posted by TNT76
    set the whole table to 13-1fuel do the auto tune thing then put the values in that you wish to run..have you read the tutorials?
    Sep 2003
    Yes read the tutorials and thought I understood it all as I thought it would be the same as the old kalmaker SP3, disable closed loop, tune ve to match commanded, turn on closed loop and it will then make its own fine corrections where 14.63 is commanded.
    Just didnt realise it was making the corrections as I was tuning.
    I didnt even have STFT PIDS logging while tuning ve as I did it with roadrunner and didnt have to autotune, log, setup maps, BEN corrections, flash and redo it.
    Will have to try it next time i'm in the car.
    Thanks for clearing it up
  1. cos3 no semi open loop
    By 64camino in forum Gen III V8 Specific
    Last Post: February 5th, 2010, 02:37 PM
  2. Setting up for semi open loop
    By jfclubby in forum Custom Operating Systems
    Last Post: September 19th, 2008, 02:56 AM
  3. Instructions for enabling semi-open loop
    By Alex99 in forum Gen III V8 Specific
    Last Post: August 2nd, 2008, 09:05 AM
  4. COS5 semi open loop ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: April 10th, 2008, 03:38 PM
  5. dfco and lean cruise in OS3 semi open loop mode
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 16th, 2005, 09:02 AM
