Results 1 to 1 of 1
Thread: January 2022, V8.3.16 Public Release
    Default January 2022, V8.3.16 Public Release
    Attention:
    Full Release Notes:
    Version Numbers:
    After installing this release you should have the following software and firmware versions installed:
    • EFILive V7 software: V7.5.43 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.3.16 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • FlashScan/AutoCal V3 Firmware: V3.00.085 (Jan 14, 2021), Boot Block: V3.00.005 (Oct 20, 2020)
    • FlashScan/AutoCal V2 Firmware: V2.08.184 (Dec 16, 2021), Boot Block: V2.08.009 (Feb 27, 2021)
    Download here:
    Download V8.3.16
    Download V7.5.43_Update_1 (calibration updates only)
    Known Issues:
    Issue #1: Importing JTAG E86B files may result in a Boot Software segment checksum error.
    Workaround: None. Don't flash imported files with checksum errors. Don't use the EFILive software to correct checksum errors for the E86B imported files as that does not fix the underlying cause of the checksum error - it just masks the error(s) and causes additional problems.
    Issue #2: When logging DMA PIDs (i.e., PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However, the DMA PIDs may no longer return valid data.
    Issue #3: Encrypted *.cax8 files will not load.
    Workaround: None. Will be fixed in the next update.
    Regards,
    The EFILive Team
  1. Oct 2017, Release Candidate 4 (AKA Public Release)
    Last Post: October 23rd, 2017, 09:17 AM
  2. Csp5 public release?
    By John0659 in forum Cummins 5.9L
    Last Post: October 27th, 2013, 09:37 AM
  3. January 24th 2011 pre-release
    Last Post: April 10th, 2011, 04:17 AM
  4. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
