Results 1 to 3 of 3
Thread: Ballenger AFR500 CAN Wideband Data Logging
    Mar 2009
    Default Ballenger AFR500 CAN Wideband Data Logging
    I've been using an AFR500V2 for the last 5-6 years and it has worked great. The analog outputs not to much.
    I grabbed their new CAN-based AFR500 and tried to get it set up while I was on the dyno yesterday. No nice.
    I followed these instructions:
    https://www.bmotorsports.com/downloa...CAN_Manual.pdf
    I can see the wideband in V8, can select the PIDs in scanner, and while data logging, the values are not coming through as sane values. I used the Ballenger CAN programmer and verified it was set to EFILive. For reference, the wideband display is showing 16:1 (free air). Here is what the data looks like in the scanner:
Name:	V8 Scanner Data.png
    00 Silverado Z71, LQ9 w/ LS3 heads, BTR cam, Whipple 2.9@8#, 4l80E
    Have you logged this as a ticket in help desk?
    I recall seeing a similar ticket but can't seem to find it now.
    Never mind, I found it, Ticket 6140.
    Do you still need help with this issue?
    Regaqrds
  1. Wideband data freezes in V8
    By ToonerSQUAD89 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 5th, 2021, 10:37 AM
  2. Can't get wideband data to show
    By pavetim in forum Petrol / Gas
    Last Post: December 30th, 2020, 01:57 AM
  3. Replies: 9
    Last Post: November 7th, 2018, 02:07 PM
  4. Replies: 1
    Last Post: September 6th, 2018, 06:47 AM
  5. Replies: 4
    Last Post: April 5th, 2017, 05:54 AM
