Results 1 to 3 of 3
Thread: V8 Scan User Defined Calcualted PIDs
    Lifetime Member Doc's Avatar
    Oct 2005
    Default V8 Scan User Defined Calcualted PIDs
    Looked through the V8 manual and searched on the forum but could not find examples of user defined V8 Calculated Pids specifically use of the the Lua 5.x scripting language.
    www.efialchemy.com
    www.greatamericancarwar.com
    You could take a look at the pre-defined calculated PIDs that are included in V8.
    Open the scan tool (F2), then use the Config->Calculated PIDs option (or press Ctrl+K), then double click on a calculated PID to see how it is defined.
    If/when you can create your own calculated PIDs, there are helpful "snippets" to the right that you can select.
    The Lua scripting language documentation can be found here:
    https://www.lua.org/manual/5.3/contents.html#index
    Oct 2005
    Paul,
    Thank you for the thoughtful suggestion. I muscled through it and got it to work. Really liking V8 more and more every day. I wish I would have started investing time in it sooner. I cannot thank you et all for such a wonderful tool.
    www.efialchemy.com
  1. Some PIDS Unavailable Based On User?
    By edwardzracing in forum General
    Last Post: November 3rd, 2020, 12:51 PM
  2. Version 8 User Defined PIDSs.
    By TFZ_Z06 in forum General
    Last Post: October 13th, 2015, 01:50 PM
  3. New user question- v2 wont log/scan
    By 496Stingray in forum Petrol / Gas
    Last Post: April 28th, 2015, 02:20 PM
  4. V8 User Calculated PIDs
    By Ninety8C5 in forum Tips and tricks
    Last Post: November 17th, 2013, 08:21 AM
  5. scan tool user manual mix up
    By Eric in forum Gen III V8 Specific
    Last Post: August 21st, 2009, 11:14 AM
